586,655 active members*
3,018 visitors online*
    Mar 2010
    84
    Macro Variable #500
    Does variable #500 have anything to do with the Renishaw probing system? I hit an incorrect button and accidently changed the value of #500. I looked at my Renishaw book and although there are some #5xx variables used, from what I read I think I'm safe. But since tearing the probe up isn't on my list of things to do, I would feel better knowing for sure if I need to recalibrate or not.
    Thanks!
    May 2004
    97
    That depends on whether you are running the WIPS version of Renishaw Probing. If your OMP40 probe has a Haas logo on it, then that is most likely the WIPS option, and the base macro variable for Renishaw Probing is #556:
    #0 to #33 Volatile (for general use)
    #100 to #119 Reserved for Haas use
    #120 to #139 Available for user
    #140 to #155 Purchased devices (probe, bar feeder, pallet changer,
    etc.)
    #156 to #199 Probe use
    #500 to #519 Reserved for Haas use
    #520 to #539 Available for user
    #540 to #555 Purchased devices (probe, bar feeder, pallet changer,
    etc.)
    #556 to #599 Probe use
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Macro b variable order
    By Diggitdude in forum Parametric Programing
    Last Post: 01-13-2014, 06:02 AM
  3. Macro/Variable Programing
    By chadr03 in forum WinCnc
    Last Post: 02-02-2011, 02:00 PM
  4. macro b local variable
    By samu in forum Fanuc
    Last Post: 12-19-2010, 12:55 AM
  5. Macro Variable Lock
    By James L in forum Haas Mills
    Last Post: 07-23-2009, 02:29 PM
