since its so hard to find actual examples of feeds and speeds that work for micro mills, im posting this to help other beginners with some kind of data point.
material: 6061-T6
diameter: 0.015"
flute length: about 0.030"
shank dia: 1/8"
tool material: carbide
flutes: 2
feed: 1ipm full slot, 0.5ipm plunge
axial depth of cut: 0.010"
speed: 7000 rpm
holder: new chinese ebay ER32 (BT30)
mill: 15 year old dyna DM2900, not sure how much runout it has, because im not sure ive measured it correctly
coolant: rustlick WS 5050 30:1 at medium flow rate
the tool path was about 51 inches long. it took about an hour of continuous milling. several plunges were made. i suppose that since the end mill survived i can call this a success. im not sure how much faster i could run it, but it would be really nice if i could run it at say 0.020" doc and 1.5 ipm..to bring 51 minutes down to 17 minutes
the finish seems to be very nice, although i havent looked at it under a microscope yet.
just to be clear, i didnt do the entire cavity with the 15 thou, it was roughed out to the point where the letters had been surfaced and they just needed to be cut out of a 20 thou tall block
