Hi everyone!
Recently I have purchased a 1290 Laser from China, the transaction was quite a pleasant experience and machine arrived configured as promised, without serious issues.
The configuration is as following:
1290 Laser
Reci W6 tube (130-150w)
Ruida RDLC320 Controller board
CW-5200 Chiller
550w Standard air blower
Small membrane air pump
I spent two days with the beastie and was able to collect some experience, in general I liked the way the machine works and software is quite OK as well (LaserWorks). I have tried to cut 3 kinds of plywood: 12mm (2/5") outdoor birch, 10mm (2/5") laser grade birch and 6mm (1/4") indoor populus. As I expected, outdoor plywood is a no go. It is terribly hard to cut and is a dirty job.
Cutting 6mm populus is like butter, while 10mm laser grade ply gave me most interesting results:
It seems as if using more power actually makes the machine less effective. The best result I was able to achieve with 10mm laser grade plywood was at 10mm/s and 25% power. Any increase in power above 25% resulted in worser / incomplete cut. From 35% and up it did not even penetrate the back side of the board. Speeding up the machine did not help either.
I am quite sure this is not a power issue, I can clearly see power increase on the burned image if I engrave test images picture with 20% to 100% power.
Does powerful beam cause more smoke which in turn diffuses the laser? And if yes, will replacing the cheap air assist pump on something more powerful be of much help? If so, what would be the right choice? Will something like this do: Mini air compressor - airbrush makeup china,airbrush compressor,airbrush compressor china,airbrush makeup,airbrush china,mini air compressor china,airbrush,air compressor-Fenghua Bida Machinery Manufacture Co. Ltd. ?
And another question: When I got the machine, I cleaned the lenses and noticed a rather well visible darkened spot on the reflecting mirrors, I assume this is where laser beam is reflected, is this normal on a new machine (Which was tested on the factory)?
Thanks!
