586,103 active members*
3,105 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Problem with variable radius fillet
    Nov 2004
    Hi all
    I am pretty new at Solidworks, and have a problem with filleting the part attached. This is a flange for the chimney of a model steam engine. I need to create a variable radius fillet between the chimney and the flange surface. A constant radius is created - no problem, but when I select variable radius, I cannot create control points at each quadrant to assign radii - why?
    Kind Regards
    Craig
    Attached Files Attached Files
    Feb 2006
    196
    Thats a good question! I tried it myself with the same result. I noticed if you try a variable fillet on the top of the chimney, it works fine. Did you contact your SolidWorks reseller for an answer?
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    May 2005
    90
    i tried it also
    i created 3d sketch points in the area for the fillet and it allowed me to specify the radius but when i clicked ok if gave me an error
    Oct 2004
    116
    I am going to take a shot in the dark here. I believe your problem comes from the fact that this file is a IGES file. Do you have this part as a actual solidworks solid part? If so post it also.
    Regards,
    D. Mealer
    May 2005
    90
    I created a quick litlle part as he did
    i got the same error
