586,096 active members*
3,459 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Help with doosan puma 300 lb
Results 1 to 12 of 12
    Nov 2013
    78
    New m/c arrived today and was installed only when we turned it on the turret wouldn't index throwing up alarm no. 2047 turret clamp switch or turret control unit alarm. What does this mean ? Could it be during transit as it worked four weeks ago
    Using Tapatalk
    Jun 2004
    511
    There is a white servo drive box in the electrical box, check to see if there is an error core displayed. If so check the book for the alarm meaning. The battery may have failed.
    Nov 2013
    78
    Thanks will look tomorrow
    Using Tapatalk
    Sep 2006
    607
    I think this was the alarm I got 4 days ago when I pressed cycle start before the turret had locked in place. I could not find it in any of the manuals, so I can't say for sure what it means. It just said to check the servo controller board. -> Good tip from ifixcnc. Tell me if you find the code in any of the manuals.
    Nov 2013
    78
    Think it might be the battery guys sounds like a simple remedy locating the battery is not though
    Using Tapatalk
    Jun 2004
    511
    Battery
    You can buy an single A holder, and just splice the wire. Radio shack has everything you need. 3.6 lithium cell and the holder. I have done this many times, and next time you just pop in the replacement cell. You will have to put the parameters back in the drive. They are in the blue parameter book.
    Nov 2013
    78
    Sounds easy I'll have a crack tommorow it showing an alp alarm on the turret drive
    Using Tapatalk
    Feb 2013
    788
    mattlynx,
    If you run into problems, give us a call.
    Doosan Infracore
    973-618-2500
    I will be out of the office for most of December(vacation and factory training in Korea), but someone in service can assist you...
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    mattlynx,
    We sell the batteries for those drives.
    Contact Lubos Mlynar, Doosan Parts Manager, for assistance in getting the right one for your machine, of the available types.
    He can be reached at [email protected]
    send him the numbers that are on the battery and he can help you get the correct replacement.
    Nov 2013
    78
    Thanks guys we located battery and should have it tomorrow hopefully then it should just be a case of restoring parameters. I think it's because m/c has been standing for so long
    Using Tapatalk
    Nov 2013
    78
    Thanks dhardt
    Using Tapatalk
    Nov 2013
    78
    Ifixcnc thanks
    Using Tapatalk
  1. Doosan Puma 400L
    By Bada Bing in forum Daewoo/Doosan
    Last Post: 06-05-2013, 12:43 AM
  2. Doosan Puma 240MSC
    By dartplayer1 in forum Daewoo/Doosan
    Last Post: 06-07-2012, 06:10 PM
  3. Doosan Puma 2100LY
    By D3abL3 in forum Daewoo/Doosan
    Last Post: 05-19-2012, 12:56 AM
  4. Doosan Puma Programming
    By _WALLACE_ in forum Daewoo/Doosan
    Last Post: 08-07-2011, 12:34 PM
  5. Doosan Puma MX3000S
    By broncranger in forum Daewoo/Doosan
    Last Post: 04-15-2009, 06:51 AM
