586,104 active members*
3,353 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > Possible cause for shaft failure?
Results 1 to 7 of 7
    Oct 2004
    832
    Anyone care to speculate on why this motor shaft broke? (see pic below)
    Hood
    Re: Possible cause for shaft failure?
    NOT high cycle fatigue...
    material defect or overtorque. Looks like an acute failure in torsion (clean grain boundaries visible plus lots of smearing on the high spots).
    What is the application/material/treatment?
    Oct 2004
    832
    It was a servo motor on the Z axis of a Chiron FZ12S VMC I retrofitted.
    15362
    Quote Originally Posted by Hood View Post
    Hood
    Misalignment has a habit of doing this over time, this is quite common with hobby built machines also, not so much machining centers but does happen
    Mactec54
    Oct 2004
    832
    I have just looked at youtube and I posted the video of the first ever job I ran on the Chiron and that video was posted April 2013 so the motor had snapped prior to that so my recollection was correct as the date of my post here is March 2013.
    15362
    Yes I can remember your video, I replied because someone else had, and have seen this happen before, seeing it was a belt drive the only why that would happen is if it was over tensioned causing the motor shaft to flex
    Mactec54
    Oct 2004
    832
    The motor was not out of alignment or at least not to any detectable amount. Also the motor connects to the ballscrew via a belt so slight misalignment shouldn't really have been an issue.
    This is an old post and I can't recall how long it ran before the motor shaft snapped but it was before I had actually finished retrofiiting it if I recall. An identical motor was fitted (I fortunately had a spare) and it has been running fine since 2013 without any modifications..
  1. How is a shaft attached to a shaft support rail ?
    By Power_user_EX in forum DIY CNC Router Table Machines
    Last Post: 06-16-2012, 12:03 PM
  2. X axis failure
    By Peter Gibbs in forum Haas Mills
    Last Post: 04-09-2012, 06:11 PM
  3. Checking Amp for failure
    By bobio in forum Fadal
    Last Post: 09-14-2011, 05:38 PM
  4. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  5. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
