I want to set-up my machine size and it seams I can only put in the dimensions in metric is that correct or can I change it to inch as my machine uses only inch?
If you are in Solidworks, I can't say 100% for sure, but in the stand alone Bobcad you would have to change your preference units to inches, at which point you can define the machine in inches. Hopefully someone with SW can help a bit more, but it should be possible as it normally is in the stand alone.
