I've purchased some Aluminium sheet 1/2" think from a local dealer, problem is it's to large for my hobby mill to edge finish. The sheet is over 1/2 a metre square and the supplier can only bandsaw cut to my required dimensions -0 +2mm. Any suggestions about how I can get a better edge on this sheet which is to be the base of my next project. I would have prefered a nice machined edge. I've large linear rails and did consider making a JIG up with my porter cable router; do you think this will work? If so what router bits as my closest store only stock the standard kitchen stuff for laminate or wood work top routing.
Dan
