I don't run my GR-510 over 50% and I am curious if there is a way to set the startup default rapid speed to 50%. Is that possible?
Thanks!
Thanks!
Have a look at Setting 10 LIMIT RAPID AT 50%
I enabled the setting, but it still powers on at 100% and I'm still able to go to 100% in a program.
Something tells me you hit the button for setting it, but did not write it and confirm. Check to see if it still on or if it back to off.
Mike
Ah yes, the ol' Write key. Thanks!
