Hi Everyone,
I recently received a PCNC770 with power drawbar and ATC. I believe that I have everything assembled and aligned correctly. I was able to cut a few parts manually changing the tool. I was also able to successfully load and fetch tools from the tray. I am using the Tormach controller with the MachOS software installed by Tormach.
However, this evening, when I set up to run a part with full fledged ATC control, I kept getting error message boxes upon tool change that say something to the effect: “Spindle is in manual mode, please switch to auto mode and press okay.” However, the spindle is not in manual mode when this comes up (and in fact has not been switched to manual model in at least one week!). After the first such error, I am also unable to load or fetch tools without getting it again. If I turn off the mill and restart Mach, it is okay for the initial tool loading at the start of my program (and I can fetch/load tools). But when the I get to the first change the message pops up again. If I click cancel, it states ATC-M6 was not completed and the program aborts.
I tried flicking the spindle switch to manual and back to auto, no effect. I still get the same behavior.
Has anyone encountered this before? Any suggestions would be appreciated. These things always seem to happen on a Friday night, and Tormach are not around until Monday.
Thanks!
Scott
