586,106 active members*
2,888 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Nothing moves in LinuxCNC, but in setup it works!?
    Jul 2009
    4
    Question Nothing moves in LinuxCNC, but in setup it works!?
    Hi All,
    I got a weird problem when running LinuxCNC. I got it all set up the same way as in Mach3 in terms of pinouts and EStop etc. I can also jog all axis during the setup and they move the correct directiona and distance.
    However, once I start LinuxCNC itself I can hear the steppers (like a relay) as they normally do, but when I try to run anything or even jog the machine it just doesn't move!?
    Any hints on what I'm doing wrong?
    Regards,
    Alex
    Jul 2009
    4
    solved it, I had the Amplifier or Enable not assigned to a Pin
    all working
  1. Replies: 70
    Last Post: 10-02-2023, 11:51 AM
  2. Help Please - Driver Setup - LinuxCNC
    By CNC pupil in forum LinuxCNC (formerly EMC2)
    Last Post: 09-08-2014, 12:37 AM
  3. Help Please - Driver Setup - LinuxCNC
    By CNC pupil in forum DIY CNC Router Table Machines
    Last Post: 01-25-2013, 04:40 PM
  4. Setting up pwm signal for Spindle in Mach3 - copying setup from emc/linuxcnc.
    By craynerd in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2012, 08:00 AM
