Do any have any experience duing this. Im a Solid cam novice
The machine is a 4 axis Word working machine
Weeke Venture 108
If any one have any imput it will be much appreciated
maby a better program if needet
Best regards Mikkel
Weeke Venture 108
Best regards Mikkel
Similar to normal vertical milling machine except when you start to use angular head holder which I am interested to know if anyone has a post processor for 3-axis vertical milling with angular head capability (A0, A90, A180, A270)? Hope someone will understand what I mean. 😰
se that is way i added the newbie but what you are describing sounds right. what i need to know is wich machine i need to tel solid cam im using. dot that make any sense?
your machine i should say i considered 3-axis vertical mill plus angular head capability. I am not sure how your angular head attachment works, whether the head rotates to change orientation and if it can orient from 0-360 degree by what increment. But you should be able to start doing 3-axis jobs with standard tools 😁. Where are you from Mikkel?
that sounds Right the angle head is manual. Im from Denmark so i just pick any of the 3x mashines?
you can pick any 3-axis post-processor and cross your finger that it will generate gcode that your machine can understand 😁. what's your machine's controller? can you post any sample program that you successfully run to the machine?
