586,094 active members*
4,177 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Inserting an excell spreadsheet
Results 1 to 11 of 11
    Nov 2005
    14
    I have a spreadaheet with a bunch of x,y,z locations, and I want to import them to mastercam as points. I have Version 9, and have looked in the help but did not find what I was looking for. Any suggestions?
    Mar 2005
    215
    I sent you a pm
    Aug 2005
    276
    this is alss of intrest to me, as I have a gear cuting program that is written in excel and also generates three seperate X, Y, and Z co-ords I use the excel feature concatinate to form a string and then save as text file but importing to MC9 or McX is my problem - will MC allow the import of G-code and then redraw images etc..
    cheers in advance
    Salty
    Mar 2005
    215
    I will not really read in a text file per say but if the files are in a specific format in excell then you could access them and create geometry based on that using vbscript. in mastercam 9 and older do "alt c" to get to the chooks...then select the mcamvb.dll file ..this will open a bar that allows you to run, open and edit vbscripts. look through the samples that are installed. There is one called excell somthing. I think that might help you the most. post one of your files and someone here might be able to help more.
    ac
    Aug 2005
    276
    I can do better than that here is the gear program
    Attached Files Attached Files
    Apr 2003
    1876
    Quote Originally Posted by Alex_Cole
    ac
    Actually, the vb scripting didn't exist until MC version 9.1. v9.0 and lower won't have it.
    :cheers:
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Aug 2005
    276
    I think I made a Boo Boo... I have just checked the *.zip I posted earlier and it's not the program I used .. HOWEVER I noticed that it does generate its own G-Gode so it will solve my problem...
    salty
    Mar 2005
    215
    sorry for the confusion my reference to v9 and older was to how to access where the chooks are. I guess I didn't word it to well. I was not trying to imply that vbs was available in versions prior to 9. I was just trying to point out how to get to it in 9 because it is in a different spot in x.
    thanks for catching my slip rekd
    ac
    Mar 2006
    1013
    I know there is a VB script for reading an excel SSheet. Mick at CNC wrote it for me to do a Cam for one of my customers. After that it ended up in the folder with all the other VBS's. Has to be 9.1 sp2 or newer I think.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Nov 2005
    14
    mike you are right, after diggin a little there is a file built in to do it. You use mcamvb.dll, as stated by alex. Then there is a file to do it. I can't remeber what it is called because I did it at work and the name slips my mind. But it puts the points up and connected them with lines.
    Mar 2006
    1013
    cam.vb If you cant find it, send me an email. I have a copy somewhere.
    Mike
