Hello,
I am working on a project where I am using a stepper motor to control a valve(open/close). Normally the motor will be connected to a constand power supply*plug*, but incase of energy malfunction I want to implant a battery that will shut off the valve (so that the valve will not be stuck in open position)
I was thinking about connecting a battery to the system where a pulse runs trough. The moment there is a energy malfunction the battery feels no pulse and then sents energy towards the motor to close it. * how exaclty this is going to work I dont know, but that is for later worries when I start talking whit the electro engineers*
For now I have sellected a motor and was wondering what sort of battery could work.
The required run time is extremely low, since it will only need to run for a maximum of two secconds when there is an energy malfunction (once a month would already be a lot). The battery does need to have a long lifetime, since the system will need to be working for atleast 10 years.
Sellected motor:
2 phase
1.5A
2 ohm
3.2 mH
0.45Nm ( 1 to 3 gearing of 1.2Nm)
required RPM: 90RPM (30RPM after gearing)
The rated voltages would then be: 2 *1.5 = 3V
Required Power becomes (KW) = 0.45 x 90/ 9.55 = 4.24 Watt
and MaxVolts ~= SQRT( 3.2 ) * 32 = 57 V
example choice of battery
TLP-91111/A/SM Flying leads 91111
3.6 V
2.40 Ah
3 A
power (watts) = voltage * current
power (watts) = 3.6 * 3 = 10.8 Watt
Run time of motor will be 2.4(aH battery)/1.5 ( ampere motor)= 1.6 hours (can I just assume the run time will be longer, because of the higher voltage its delivering, 3.6V compared to 3V)
I think I am making a lot of mistakes in this part of the project, since I have no knowledge in batterys.
Therefor I was wondering if someone could give me some guidelines of how I could choose a battery for my system. What am I overlooking at this moment and how can I determine the minimal required battery (voltage / current /aH)?
Any given help would be greatly appreciated.
