586,042 active members*
3,716 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Badly traced dxfs on a plasma cam
    Dec 2013
    I am considering a plasmacam, I currently work at a fab shop with a waterjet and want to do similar things on the side and the tiny plasma tables are what is in my price range. my question is, A lot of times ill use third party software to trace a jpeg or other image file to a dxf, sometimes the jpegs are low quality and result in a pretty sketchy dxf, usually this isn't a problem on the $300K machine with no heat affected zone or dross, the end result is acceptable. what kind of clean up would I have to do on something like this on the plasma cam im guessing all of the tick marks and small detail "blobs" would have to changed to single lines?
    Attached Files Attached Files
    May 2012
    36
    I've been playing with a friends new plasma cam and very surprised how easy cleanup is with their software. Had somebody just trace out an item, scanned it had 600 dpi and within three minutes we were cutting it out. Use the smoothing option with a .01 smooth and everything looked great.
    Jan 2008
    2247
    With PlasmaCams latest software (Design Edge") scanning in a file and converting it to a .dxf is easy. There is a little bit of a learning curve, but it is the best software I have used to do this task.
    Jim
    Quote Originally Posted by berkbria View Post
  1. DXFS, Splines, Polylines, Ellipses and Headaches
    By 88incher in forum Waterjet General Topics
    Last Post: 09-01-2016, 03:55 PM
  2. traced out an electric guitar body using a portable drawing
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 02-20-2013, 03:21 AM
  3. Wind spinners (Who's made, DXFs)?
    By Orangejbird in forum Machine Created Art
    Last Post: 03-12-2009, 02:12 PM
  4. Thunderbird & DXFs... Can we find a solution?
    By InspirationTool in forum OpenSource Software
    Last Post: 07-07-2007, 02:03 AM
