The Neuron.THC is a ARM microprocessor-based torch height control system which controls the torch-to-work distance of a plasma torch during cutting operations. The system includes a control module, plasma system interface module, interconnecting cables and optional operator control module.
Сontrol module has a size 125x150 mm and can be easily integrated in the CNC. Connection is very simple.
-Works with all plasma cutting systems.
-Connect via Ethernet interface to Mach3 CNC and controls Z axis directly (internal PID closed loop - 500 uS servo cycle) . No additional parallel port or port multiplexing.
-All Parameters are set and displayed from Control Panel integrated in Mach3 (the control panel has a size of 450x330 pixels and can be used with your favorite ScreenSet). Quick access and changing of all parameters.
-Unlimited number of cut profiles for different metal thicknesses. Quickly switch between profiles and the ability to quick edit them.
-No matter to set parameters in G-Code.
-Set point resolution - 0.25V
-Set point range - 25 - 250V (set just by clicking the mouse button and wheel on the Target Arc Voltage textbox on ControlPanel or turning the encoder knob on the operator panel)
-Maximum control accuracy - +/-0.25V
-Voltage feedback (divider) - 1:20 (Hypitherm), 1:10 (internal) of Arc Voltage
-Buffered Step & Direction for direct interface to Motor Drive (26LS31 Driver).
-All inputs (include arc voltage) are isolated and Simple wiring (RJ45 connectors).
-Sample voltage mode - THC measures the voltage at the end of the AVC Delay and uses it as a set point for the remainder of the cut.
-Skip IHS mode - If the next starting point is within this distance of the end of the previous cut, the THC skips the IHS.
-Improved Jog - the lifter initially jogs 0.25 mm. After 0.5 second, it begins continuous motion at the IHS Speed. After 1.5 seconds, the lifter increases the speed to the programmed Manual Speed.
-Jog just by clicking the mouse button and wheel on the Position textbox or by pressing the up / down button on ControlPanel.
-Automatic control of ventilation.
-Preflow during IHS and Pierce End output signals.
-Built-in pierce and cut time counter to control consumables.
-Integrated diagnostic system informs the operator of the errors that occurred.
-Plotting the arc voltage and save to file for diagnostics.
-Easy Software update using the utility NeuronFlasher.
detail.......https://sites.google.com/site/thcneu...on-thc-english
Price 673$ PayPal accepted. Worldwide delivery.
Attachment 213052 Attachment 213054 Attachment 213056 Attachment 213058
