586,060 active members*
4,339 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Visual Basic > Emco Compact5 Interface (like Weledit)
Page 2 of 3 123
Results 21 to 40 of 51
  1. #21
    Sep 2008
    32
    I just bought a Compact 5 PC lathe and could really use a copy of the old DOS software that originally came with the machine. I will look at the recommendation for newer stuff after getting it working on the original. Any help appreciated. [email protected]
  2. #22
    Apr 2008
    Just got 3 emco small lath. I have everything with them but looking for something more windows like.
    Nice project. Find the serial code and make an win interface that send words to the emco its funny. I did with an old plotter far in the past :-).
  3. #23
    Dec 2006
    839
    Quote Originally Posted by maniso View Post
    As i can see is there back some interesting in the Compact 5.
    I will atach the self installing utilitie to use te simulationprogram and communication to the EmcoLatch.
    Hope that i can help more persons whitch are wane use it.
    Have fun .
    Could you send all that you have, thanks?
    [email protected] )Take out the two dashes in the Email for it to work. THis way all the spybots want get my email.
    Thanks, Jess
  4. #24
    Aug 2007
    21
    Is there some one ho can explane how i can add a attachment to the message?
    i try it before withe no succes.
    Thanks.
  5. #25
    Jan 2009
    24
    Hi Maniso,
    if you can't upload your update version of Mike's interface, is it possible to send it by email?
    I am really interested in your work.
    Have fun .
  6. #26
    Aug 2007
    21
    Are You interesting in the exe-file or in the source-file, becours i add some things to it and do net have the time at the moment, someone ho can finisch it up and put it on this forum so more can injou it.
    Send me You mailadress.
  7. #27
    Jan 2009
    24
    Hi Maniso,
    please send me all files.
    I would like to see if I can finish your work.
    I have sent you my email address through the personal-message system.
    Please let me know if you received it.
  8. #28
    Jan 2009
    24
    Hi Maniso,
    thanks for the files.
    I will let you know.
  9. #29
    Jan 2009
    24
    Mike's Free Interface for EMCO C5CNC has been updated by Maniso.
    He added/fixed the Toolpath Preview:
    G02/G03/M99 (partial) Arcs
    G24 Radius programming in absolute mode
    G25 Jump to SUBroutine
    G27 Jump
    G33 Threading
    G90 Absolute mode
    G91 Incremental mode
    G92 Set Zero Point
    M17 Return from SUBroutine
    I created a setup.zip for this update.
    I will send you the file if you want.
    Henk
  10. #30
    Jan 2009
    24
    I am working on the next updates.
    You can dowload the latest version from the Mike's Free Interface pages:
    www.mikesfreeinterface.com
    Henk
  11. #31
    Jan 2009
    24
    Update Mike's Free Interface for Emco Compact 5 CNC
    Hello to all,
    well all, just the owners of non retrofitted Emco C5CNC machines.
    If you are like me still using the original Emco controller,you could either be clever or download the newest version of Mike's Free Interface.
    I am starting to understand how the program works, so now I can update the program as I like.
    If you have any ideas, let me know (or just wait for me to work through my todo list)
    Anyway, 1.2.1 is now ready for downloading.
  12. #32
    Jan 2009
    24
    Just to let you know, update 1.2.2 is on the site for downloading.
    Thanks to some input of users, V1.2.3 is getting close to finish now.
    If you wish, you also may put any feedback or requests on the forum of
    Henk
  13. #33
    Jan 2009
    24
    Mikes Free Interface
    Now V1.2.3 is ready. It has automatic M99 calculation, at the moment for just one quadrant at a time . Next step would be to have it calculating more than one quadrant and to allow the desired angle as an input.
    The idea is that when defining a partial arc, you must know start and end of the
    arc, and either center coordinates or radius or angle.
    While Center Coordinates being the standard Emco way, MFI now offers also M99R, which is the radius method. In the future M99A (for Angle) method could be a useful addition.
    I also added some other features too.
    Henk
  14. #34
    Jan 2009
    24
    Help. Please send me a MK2 file.
    I need a little help now.
    Up till now MFI only works with MK4 lathes. Now I want to make a MK2 option in next version, but I don't know how a MK2 file looks like exactly. So please, can someone send me a MK2 file, just an example with a few different G codes in it.
    Please send it to hank.varschuran@... (replace each "a" for a "e" to make the email address work)
    Latest version 1.2.3 (www.mikesfreeinterface.com) now has these features:
    * M99R, automatic M99 CALCULATION
    * TOOL POSITION display
    * AXIS PROPERTIES window
    * ARC PROPERTIES display
    * AUTO COMMENT option
    * AUTO M30 adding
    * AUTO RENUMBERING
    * FEED PRESET / FIND & REPLACE
    * MATHEMATIC INPUTS
    * CALCULATOR
    * CONVERTING mm <> inches
    * RUN option right from the editor
    * EMBEDDED DEBUG COMMANDS
    * PARAMETER CHECK running in the background
    * VIEW RADII will visually show the radius
    * AUTO FIT sets Scale and ZeroPoint for best fit
  15. #35
    Jan 2009
    24
    Now MFI has MK2/MK4 option.
    When creating a new file, you can choose in the settings for MK2 or MK4. When opening an existing file, MFI will recognize the format itself.
    MFI can be downloaded from www.mikesfreeinterface.com
  16. #36
    Jan 2009
    24
    www.mikesfreeinterface.com V1.2.5 has now French, Dutch and English user interfaces.
    Users may add new languages as they like.
    Henk
  17. #37
    Nov 2004
    260
    Just tryed downloading the latest version 1.4.1e and my Norton antivirus Program flagged this file as Infected. May want to look into this?
  18. #38
    Jan 2009
    24
    Hi Torsten,
    I tried but I couldn't replicate the error you reported.
    Then again, I am running AVG virus scanner, not Norton.
    I will see if I can find somebody who does. Will let you know.
    Henk
  19. #39
    Mar 2006
    113
    I use Zone Alarm did an advanced scan downloading 1.4.1e and it did not find any issues.
    Dan
  20. #40
    Jan 2009
    24
    Could it be a standard warning when downloading exe files?
Page 2 of 3 123
  1. emco compact5 cnc
    By edkaar in forum Mini Lathe
    Last Post: 02-14-2010, 02:58 AM
  2. Interface cards for Emco Mills & Lathes
    By kcarey in forum Benchtop Machines
    Last Post: 11-08-2007, 03:01 AM
  3. Need help on EMCO Compact5 CNC RS 232 cable
    By c_aguit in forum DNC Problems and Solutions
    Last Post: 11-07-2007, 07:30 AM
  4. Interface cards for Emco Mills & Lathes
    By kcarey in forum DeskCNC Controller Board
    Last Post: 05-01-2007, 06:41 PM
  5. EMCO Compact5 CNC help needed.
    By ESjaavik in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2005, 07:08 PM
