586,082 active members*
3,807 visitors online*
    Dec 2013
    Error code I01
    I have a Maho mh800e
    When i start the machine if give a Error code I 01 what Meansville that there is no. Connexion between the software and the hardware .
    The machine has the Philips 426 controle
    I check the emegecy stops en the limit switches
    When i push the hydrauliks bottom it workshop but it wil not. stick
    Please help
    Mar 2007
    64
    you need to press the hydraulics start button, hold it down and press the "clear" button on the keyboard, release them and do it again. It has to be done within 3 seconds of each other. IE:hydraulics on press the "clear" button....release and do it again no more then a 3 second time gap between. If the hydraulics don't stay on you have a deeper problem. simple things to check for are, all the emergency stop buttons are released, none of the XY or Z axis are on a hard limit switchs. If it's not that you need to be able to follow a schematic diagram and have a decent VOM. Do you have the schematics for your machine?
  1. G code error
    By skylanehku in forum CamBam
    Last Post: 10-14-2012, 06:15 AM
  2. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  3. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
  4. G code error with CAM
    By greeps in forum Dolphin CAD/CAM
    Last Post: 07-02-2011, 03:44 AM
  5. M01 error code
    By MRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-12-2006, 01:59 PM
