586,036 active members*
3,446 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > HELP!!! DYNA 3300-B Lathe with Mitsubishi Meldas 50L
Results 1 to 7 of 7
    Jan 2010
    29
    Hello Guyz;
    I'm trying to run a Dyna 3300-B lathe with mitsubishi Meldas 50L/50G control. I don't have the operation manual nor the programming manual, PLEASE! can someone help me with the information :bs:
    Nov 2009
    4415
    I have a manual or two on the 3000 & 3000H. Pm me your email and I will send what I have. If it would be of help.
    24221
    There are some manuals on the MEAU site for the 50L. Look in Documentation.
    For Operator manuals you may have to look at the 500L as they are close.
    Al.
    Albert E.
    Jan 2010
    29
    Nothing can be found in internet please fastest1, can you help me?... I will be grateful and help you if you need.
    Nov 2009
    4415
    Roberto, did I not send you the manual? I will be glad to send what I have. Pm me your email (I believe you already have, I am mobile at the time of this post.
    A lazy man does it twice.
    Re: HELP!!! DYNA 3300-B Lathe with Mitsubishi Meldas 50L
    Unfortunately, I don't think the Dyna 3300 shares much if anything in common with the 3000 or 3000H models.
    Roberto
    Puede bajar el manual con la siguiente liga:
    https://www.dropbox.com/s/57qocmk8y3...press.pdf?dl=0
    Saludos...
    Jose Monroy
  1. Meldas 325LGV CNC Lathe MTC10B Mitsubishi
    By Monster_Shop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-09-2019, 05:50 PM
  2. Replies: 20
    Last Post: 10-18-2019, 09:41 PM
  3. Dyna Myte/Mitsubishi Meldas 520M/Servo parameter adjust?
    By DynaMyte4400 in forum Dyna Mechtronics
    Last Post: 05-09-2014, 03:53 PM
  4. dyna myte 4400m with meldas cam3 ATC error
    By ptkk in forum DNC Problems and Solutions
    Last Post: 04-14-2013, 06:23 AM
  5. Dyna Mite with Meldas 520
    By cncfirst in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2007, 06:54 PM
