586,055 active members*
4,352 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Trouble Rotary Milling with CPLs on a Part's Outside Diameter
    Jan 2012
    13
    Question Trouble Rotary Milling with CPLs on a Part's Outside Diameter
    I would like to define a CPL on the OD of a part, but still treat the holes as radial holes, rather than vertical holes. This would mean the part would rotate on an "Index", but the CPL should not. In Edgecam the CPL moves in Y and Z, unless it is located on the center line. Is there any way to change this behavior?
    I hope the picture attached helps make my issue a little more clear.
    May 2004
    142
    Re: Trouble Rotary Milling with CPLs on a Part's Outside Diameter
    All you need to do is move the part to the initial cpl... or create a cpl and use it for the sequence.
    Are the holes pointed at the center? Im not sure why you would want to rotate about a non center cpl
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
    Jan 2012
    13
    Quote Originally Posted by helix77 View Post
    Thanks for the reply.
    The holes are usually pointed at the center, but not always.
    The machinists like having Z0 at the top of the part, rather than the hollow center. If I make separate CPLs then I have to manually edit the GCODE by hand to fix all the work coordinates, and it posts separate canned cycles so it makes the code more verbose. If I leave the CPL at the center I have to use an NC editor to do Z shifts.
  1. Choosing rotary encoders for a slow, large diameter turntable, angle control.
    By noeltam75 in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2012, 02:35 AM
  2. How to cut large diameter thread with milling machine.
    By ngwanhoe in forum MetalWork Discussion
    Last Post: 04-01-2011, 04:04 PM
  3. rotary table trouble
    By Paul Russel-Smi in forum Cincinnati CNC
    Last Post: 03-11-2009, 11:47 AM
  4. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  5. having trouble finding this part
    By david90 in forum DIY CNC Router Table Machines
    Last Post: 12-13-2007, 12:32 PM
