586,100 active members*
3,160 visitors online*
    Dec 2013
    heidenhain 155
    I have a heidenhain 155 operating a beaver VC35
    I have a carousel tool changer which works fine in a program
    on man/auto tool change the man/auto button will not release the tooling and also cancels the facility to use the handwheel on the xyz axis
    I guess the solenoids are ok as the auto tool changer is working in prog mode
    I have to emergency stop just to re activate the hadwheel facility.
    Any ideas
    Oct 2007
    179
    Hi that sounds like a possible wiring issue on the man/auto button...or the plc is playing up..
    John
    Oct 2009
    4
    Get in touch with msscnc.com
  1. heidenhain tnc 426
    By soulmike in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-02-2013, 03:48 AM
  2. heidenhain tnc 426
    By balavishe in forum Uncategorised MetalWorking Machines
    Last Post: 08-20-2012, 07:21 AM
  3. Heidenhain TNC 426
    By zoeper in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2012, 10:45 PM
  4. Heidenhain DRO
    By mmri1 in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2009, 04:34 PM
  5. Old Heidenhain DRO Help!?
    By scubasteve_911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2008, 03:29 AM
