586,416 active members*
3,836 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > A simple chip and coolant deflector
Results 1 to 2 of 2
    Dec 2010
    66
    Most all of us quickly discovered that the original equipment chip deflector panel is a joke. It's a pain to slide the panel into the slots and chips and coolant easily fly over the top.
    There's been a lot of clever solutions posted here -- various enclosure designs with doors, curtains, etc. For the less ambitious I have an easier solution: the pictures attached explain better than a lot of words. The lexan panel is weighted by a piece of aluminum tube that I happened to have at hand. When I need to change parts or tools, I just flip it up to one side or the other where it can drain back into the enclosure. Flipping the panel to the side is quick and easy.
    I have been using this arrangement in production for more than a year and have found it to be 100% effective. Putting the panel closer to the action means that a smaller panel covers a larger solid angle of spray. And if you are wondering... no, there is no spray that goes under the panel and gets out. If I were doing it over, I'd probably make it just a little narrower to the left and right: maybe 26" wide by 10" tall.
    Attachment 213874
    Attachment 213876
    Jan 2012
    714
    I used something similar on the old Bridgeport to keep it from throwing chips at me as well as all over the floor!
    I use a back splash or bib on my Tormach to keep the chips on the table and a shower curtain around the spindle, it works for about 90 percent of the chips.
    mike sr
  1. Containers for chip/coolant recovery
    By Pharkas in forum MetalWork Discussion
    Last Post: 01-25-2015, 12:46 AM
  2. New Table chip/coolant guard
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 01-22-2014, 09:48 PM
  3. Chip/Coolant Containment
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2012, 03:54 AM
  4. Bed Mill chip deflector or encloser??
    By Gundawg in forum Uncategorised MetalWorking Machines
    Last Post: 11-22-2011, 02:16 AM
  5. VM-2 coolant/chip problem
    By extanker59 in forum Haas Mills
    Last Post: 11-08-2011, 03:40 PM
