586,121 active members*
3,493 visitors online*
Results 1 to 8 of 8
    Aug 2013
    CNC aluminium surfacing random indent
    Hey everyone, I'm new to cnc milling. I got a Chinese 6040 routing machine with gecko g540 controller. I wanted to surface my table using the mach3 surfacing wizard, before starting with the surfacing I tried it out on a piece of aluminium with a 6mm end mill bit just to test the finish. There are some arbitrary indents on the surfaced piece of aluminium that looks like the z-axis has moved by very small increment but I don't have anything in the code that indicates that behaviour. I'm posting a few pictures of the finish, can someone look at the pictures and tell me what could of possibly caused it and how can I improve the finish?
    Oct 2012
    87
    Try it again with a high positive new cutter. Not coated. Use a little bit of WD40 as lubrication. It may be swarf under the cutter. As the cutter rotates it traps the swarf under the cutting edges.
    Alan
    I think it should be the possible cause of spindle or axis vibration. check your spindle run out.
    you may try this.
    spindle assembly. run out problem. spindle bearing.cncmachinetools.org
    Oct 2005
    278
    I dont think you have enough rigidity. the cutter is riding up on the workpiece (table) and then drops down and cuts deep when the material hardness changes or it just gets toom much downward pressure built up.
    Use a VERY sharp hss cutter with lube.
    Nate.
    Ann Arbor Meechigan
    Apr 2009
    5516
    You probably could take a shallower cut. I wouldn't slow the federate down, but would increase the spindle speed. Also agree with everyone else - use LUBE; you don't need a lot, just brush some WD-40 over the workpiece....
    Aug 2013
    Thanks for the reply everyone,
    i have tried using lubricant, different types/sizes new cutters(HSS, carbide) and also a new spindle but its still happening. i believe its caused by some sort of movement in z axis when the stepper motors are moving, due to the table possible not rigid enough. it was happening on a piece of nylon where i was taking 1/10 of mm, the only thing i haven't tried is to cut in Y-axis rather than X to see if i can get that crescent moon shape in other direction.
    Oct 2013
    188
    Quote Originally Posted by SinghAnmol View Post
    I know it's not a milling machine but I was getting rings on my 6061 tubing on the lathe. Tried everything, turns out the brass plug was moving in the tube so I switched to a bull nose with bearings and no movement. (Rigidity problem) In the photos is carbide on the left and Cermet on the right, no lubricant.
    May 2005
    3920
    The first thing I thought of was as Alan described above, swarf either getting hung up on the end mill or recut.
    Some have mentioned rigidity which is always an issue on these cheap routers. If that was the case I would think that you would be seeing lots of these imperfections. That being said, what type of spindle do you have? If it is a simple router end play in the router might cause some issues but to be honest this doesn't look like end play. It looks more like a scuffing of the surface as opposed to an anomaly caused by tool deflection.
  1. Aluminium passivation - for aluminium to be used outside
    By hudsonlighting in forum Mass finishing equipment/media/strategies
    Last Post: 04-06-2011, 06:06 PM
  2. Need help surfacing!!!
    By kbeard in forum Musical Instrument Design and Construction
    Last Post: 06-08-2010, 10:38 PM
  3. Surfacing
    By SyilAmerica in forum Syil Products
    Last Post: 12-17-2007, 06:38 PM
  4. Solidworks 2005 - Indent Feature - How?
    By creative_mind in forum Solidworks
    Last Post: 10-08-2004, 01:47 PM
  5. surfacing help
    By lt paul in forum Rhino 3D
    Last Post: 07-16-2004, 03:48 PM
