586,116 active members*
3,313 visitors online*
Page 1 of 3 123
Results 1 to 20 of 56
    Nov 2012
    54
    Lightbulb Purchase CNC from XYZ Tech for my Friend
    Hi All !
    After a long websearch, I have selected 3 manufacturers as Roctech, Sudiao and XYZ-Tech. Started on long emailing with all of them, I got a lot of informations from all, specially Roctech looks the most professional, but others also has some ideas.
    The first input where the working size 600x900mm, so that specify the machine range. Base machines almost on all cases where equipped with stepper, chines spindles. Finally I have agreed with all 3 manufacturer the below parameters:
    Construction *8mm*steel*tube*for*gantry*&*6mm*steel*tube*for*st ructure
    Frame Welded structure
    Working area 600*900*200mm
    X,Y,Z Traveling Positioning Accuracy ±0.01/300mm
    X,Y,Z Repositioning Accuracy ±0.01mm
    X,Y Resolution <0.01mm
    Z Resolution 0.01mm
    X,Y,Z Transmission For Y 3210 TBI , for X,Z axis 2510 TBI ball screw
    X,Y,Z Guiding And for three axises, min. 20mm Hiwin linear
    Spindle HSD Italy air cool Spindle 3kw MT1073-Y6162Y0014
    Spindle driver Delta inverter(VFD-037 B 43A)
    Spindle Speed 0-24000RPM
    Collet ER25
    Control system Ncstudio control system
    Driving servo motor (SGMGV-09ADC61)Yaskawa 850W
    Servo motor Driver (SGDV-7R6A01)AYaskaws 850W driver
    Table Surface Aluminium T- slot table + PVC
    Lubrication system manual or auto oil Lubrication
    Tool sensor Tool sensor
    adding to each one the quoted price too and rotary options.
    Showing all 3 offers into one excel sheet to my friend he has selected not the cheapest one, not the most expensive one. Based on available companies informations and provided details he selected XYZ Tech. The machine will be ordered soon. I will update time to time this forum to provide some input/review for next interested newbies.
    Here I would like to thank for all 3 manufacturers patient emailing, time and all details provided.
    Nov 2012
    54
    The deposit of aprox. 30% where transferred few days ago. Today I received a phone call from XYZ Tech (sweet voice of Hellen who is my contact). We continued the discussion using Skype. I have been informed that Yaskawa servos are out of stock and can I accept Panasonic servos instead. As my friend agreed Yaskawa, I asked also for that. This will delay the delivery, aprox. 10 days.
    Nov 2012
    54
    A week passed, and after a lot of discussions I got first pictures. It where hard to obtain them as the welding is done by subcontrators, not by XYZ itself. Unfortunately I got pictures about the welded structure so I don't know the tubes wall thickness, but I hope the required 8mm where used. The 3210 ballscrew creates also problem for XYZ as they commonly use 2510, so just now they have to order the 3210. I know that I asked a customized machine, but from here it looks a little that all differencies creates some difficulties.
    Here are the pictures that I got.
    Attachment 216042
    Attachment 216044
    Attachment 216046
    Some more pictures are promised, so once I will get them I will post them, till I ask for your patient.
    15362
    zszabo
    The Yaskawa 850W is a big motor for that size machine, 750W would of done it with ease, the frame looks OK, if you want to use the max RPM then stay with the 32mm ballscrew, the motor will run up to 5,000 RPM
    On the control NC studio, make sure you are getting the the real thing, as most are a copy, & do not always function correctly
    Mactec54
    Nov 2012
    54
    Hello Mactec54,
    Thank you for watching and comments. Yes the 850W may be little stronger than needed, but I think is better than the originally offered 400W. The machine is planed to be used in CEM1, paper laminates, PC, FR4 of min. 15mm, but the precision is most important, as the plates will be used for pcb test machines and must fit tougether. The high speed is not important on servo side, more important on spindle side as there are needed to drill small holes on exact coordinates.
    Today I got the original, higher resolution pictures. Totally 4, one more than before. Here is the 4th too.
    Attachment 216174
    More status pictures are promised, so once I will got I will post them too.
    Nov 2012
    54
    New pictures arrived today about the Gantry.
    Attachment 216408
    Attachment 216410
    Attachment 216412
    Attachment 216414
    My friend added some comments as the Brand is not visible on the guides and not all fixing screws are on.
    Attachment 216416
    Hellen confirmed that original guides are used, she will send pictures about it after she is back from new year holiday.
    Happy New Year for everyone !
    Nov 2012
    54
    New pictures arrived today.
    Attachment 217010
    Attachment 217012
    Attachment 217014
    Attachment 217016
    Attachment 217018
    Attachment 217020
    The 850W servos looks little big on the machine, so I don't think that will be a problem for them to make it to move. The Z axe is drived by belt, so Im afraid a little about the precision as the belt can elongate. The guiding are still fixed just with each second screws on each 3 axes, so I have asked again to add all screws.
    As the machine will be used in most cases into laminates, Hellen offered to pack some sheets with the machine if I select a supplier. This a very kind offer as I can get 2 in 1 with less shipping cost.
    15362
    zszabo
    The belt drive should not be a problem,But the pulleys look to be to small in diameter, you could always change it to the Gates Gt3-5 or 8 if you did have a problem, I don't see any machining of the linear rails & ballscrew mountings areas
    Mactec54
    Nov 2012
    54
    Thank you Mactec54 for your opinion,
    I realized also that is not machined, but I got the pictures just now when is already assembled. Some machining is visible on gantry rails area, but also there Im not sure is is done under the rails and other sensitive parts
    If you have any ideas or comments that is not to late to ask that is welcome.
    Thank you again for your comments.
    Sep 2005
    1195
    Zszabo,
    How much such machine cost you? Thanks.
    Nov 2012
    54
    Asuratman
    As this deal is ongoing I have sent the price in a PM message to you.
    Sep 2005
    1195
    That is OK, machine delivered in your city, strong structural machine and servo.
    Nov 2012
    54
    Thanks, I have selected each part and agreed with supplier. The construction looks a little homemade than industrial as Mactec54 remarked, but I hope that finally will work fine. Anyway if you came back time 2 time you will see here the outcome of this deal.
    Nov 2012
    54
    Some photos about the servo motors
    Attachment 218050
    Nov 2012
    54
    Nov 2012
    54
    I got new pictures.
    The guiding looks Hiwin
    Attachment 218200
    Spindle driver VFD-B
    Attachment 218202
    Servo driver
    Attachment 218206
    200V transformer
    Attachment 218204
    All tougether
    Attachment 218208Attachment 218210
    Machine under construction
    Nov 2012
    54
    Pictures of the spindle
    Attachment 218592
    Attachment 218594
    and driver
    Nov 2012
    54
    And updates on the machine
    Attachment 218600
    Normally should be shipped within this week
    Nov 2012
    54
    Nov 2012
    54
    Machine in the wooden box, ready for shipping.
    Attachment 218640
    Attachment 218642
    Attachment 218644
    ... follow up once received the machine or something happens....
Page 1 of 3 123
  1. New purchase and first impression of EXLAS X4I Laser cutter from XYZ-Tech
    By mikevanoostende in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-22-2016, 09:11 AM
  2. Need a low tech solution to a high tech problem (kind of urgent)
    By PeliTac in forum Want To Buy...Need help!
    Last Post: 01-23-2014, 05:05 PM
  3. Looking for a Friend
    By ltmquik in forum Fadal
    Last Post: 05-08-2010, 05:17 PM
