Hi All !
After a long websearch, I have selected 3 manufacturers as Roctech, Sudiao and XYZ-Tech. Started on long emailing with all of them, I got a lot of informations from all, specially Roctech looks the most professional, but others also has some ideas.
The first input where the working size 600x900mm, so that specify the machine range. Base machines almost on all cases where equipped with stepper, chines spindles. Finally I have agreed with all 3 manufacturer the below parameters:
Construction *8mm*steel*tube*for*gantry*&*6mm*steel*tube*for*st ructure
Frame Welded structure
Working area 600*900*200mm
X,Y,Z Traveling Positioning Accuracy ±0.01/300mm
X,Y,Z Repositioning Accuracy ±0.01mm
X,Y Resolution <0.01mm
Z Resolution 0.01mm
X,Y,Z Transmission For Y 3210 TBI , for X,Z axis 2510 TBI ball screw
X,Y,Z Guiding And for three axises, min. 20mm Hiwin linear
Spindle HSD Italy air cool Spindle 3kw MT1073-Y6162Y0014
Spindle driver Delta inverter(VFD-037 B 43A)
Spindle Speed 0-24000RPM
Collet ER25
Control system Ncstudio control system
Driving servo motor (SGMGV-09ADC61)Yaskawa 850W
Servo motor Driver (SGDV-7R6A01)AYaskaws 850W driver
Table Surface Aluminium T- slot table + PVC
Lubrication system manual or auto oil Lubrication
Tool sensor Tool sensor
adding to each one the quoted price too and rotary options.
Showing all 3 offers into one excel sheet to my friend he has selected not the cheapest one, not the most expensive one. Based on available companies informations and provided details he selected XYZ Tech. The machine will be ordered soon. I will update time to time this forum to provide some input/review for next interested newbies.
Here I would like to thank for all 3 manufacturers patient emailing, time and all details provided.
