586,700 active members*
3,122 visitors online*
Thread: worm gear
Results 1 to 8 of 8
    Dec 2013
    21
    worm gear
    Hi I am using cnc milling and mach 3 im new to this hobby and would like to cut a worm gear with 4th axis rotary table how do I set the codes to cut diameter 76mm
    any help who did it before how to set codes???
    thankx
    May 2005
    3920
    Normally I would think of that as a lathe process. Maybe somebody that has actually done this on a mill will post but at the very least you would need a forth axis. I'm thinking here the long pinion that drives the gear as the "worm gear".
    Nov 2009
    4415
    worm gear
    There is probably a wizard for it somewhere.
    I remember writing some GCode that did just that. I used a Sherline rotary table set up so the axis was parallel to the X and workpiece was horizontal. I used a ball end mill and rotated the piece as the X was advancing. I also used a tailpiece. It looked much like a ballscrew when I was finished. Or a column.
    Someone in the forum told me the code to write or how to write it. It was pretty simple in its length (the code) but I can't remember how to do it now.
    Look what I found in the scrap pile!
    A lazy man does it twice.
    Jan 2013
    119
    Are you wanting to cut a worm gear , or the worm?
    Dec 2013
    21
    HI
    i need to make/cut the worm 76.5 diameter please I need the g codes
    Dec 2013
    21
    the worm with 2 float its 10mm size and 76.5mm diameter of worm
    Jan 2012
    789
    I'd look at Gearotic. Bob Warfield has been promoting it-
    Welcome to Gearotic Motion - CNCCookbook CNC Blog CNCCookbook CNC Blog
    Never used it, it just comes to mind.
    Dec 2013
    21
    Thank you for the link il have a look and hopefully get somewhere
  1. Horizontal Saw Worm Gear
    By Shanghyd in forum Want To Buy...Need help!
    Last Post: 01-30-2010, 02:54 AM
  2. Need some help finding worm gear oil
    By Dustin L in forum Linear and Rotary Motion
    Last Post: 11-04-2008, 09:32 PM
  3. Worm gear and worm drive
    By LEWENZ in forum Employment Opportunity
    Last Post: 04-27-2008, 10:28 PM
  4. Worm Gear
    By jackson in forum MetalWork Discussion
    Last Post: 02-07-2008, 10:25 PM
  5. worm gear drive
    By csrc in forum DIY CNC Router Table Machines
    Last Post: 07-03-2007, 08:53 PM
