586,069 active members*
3,500 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > I need help with Fanuc pin-assignment connector (JF-1 / the pulse coder cable)
    Nov 2011
    28
    I need help with Fanuc pin-assignment connector (JF-1 / the pulse coder cable), I have Fanuc driver model A06B-6117-H105 (E) Fanuc Servo Amplifier Alpha iSV 1-80, and I’m having problem with cable between the rotary table (Parkson model: PNC-201) and the Fanuc driver, the problem is that the connector (on the side of the Fanuc driver) is totally broke and I lost some of the pins from the connector itself (it’ll be a hell of work the replace the whole cable) for that I bought new connector for the driver side (JF-1) but I don’t know the pin-assignment for it.
    Please I need help to connect that connector the right way, I can do the cable buzzer test from the motor side to get to the right end for it.
    Rotary table information:
    1- Model: Parkson PNC-201
    2- Motor model: Fanuc A06B-0223-B001
    3- Pulse encoder model: A860-2005-T301
    Fanuc driver information (4th axis):
    1- Fanuc Servo Amplifier Alpha iSV 1-80, model: A06B-6117-H105
    P.S. kindly check the pictures I attached for the rotary table information.
    Dec 2013
    5
    Attachment 214590
    Here you go
    Feb 2014
    I had the same problem in a Fanuc oi-mb but my problem is that i don't know how to connect from the jf1 to the jn2 (japan aviation connecto..the one with letters instead of numbers). I wanted to know what number from the jf1 is connected to each letter of jn2.
    Sorry if I had a bad english.
    thanks for your time
  1. Fanuc ABS pulse Coder
    By jmelson in forum Fanuc
    Last Post: 08-07-2013, 04:08 AM
  2. Fanuc pulse coder pinout?
    By Jonne in forum Servo Motors / Drives
    Last Post: 02-02-2013, 03:49 AM
  3. Fanuc absolute pulse coder pinout?
    By jsheerin in forum Fanuc
    Last Post: 06-04-2012, 02:15 PM
  4. Fanuc pulse coder wanted!!!
    By usedcncmt in forum Want To Buy...Need help!
    Last Post: 02-12-2011, 02:02 AM
  5. Fanuc Pulse Coder
    By Derek.C in forum Fanuc
    Last Post: 01-04-2007, 03:24 AM
