586,596 active members*
3,292 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > No motor movement using mach3 and g540
    Dec 2013
    I have a x2 mill I am converting to CNC. I cannot get any motor movement. I loaded the 540xml file from geckodrive for the g540. Checked configuration and found no errors. With I power up the driver the motors lock up and you cannot move them by hand. I can run a wizard and see it move on the screen but no movement on motors. On the g540 there is a green light and the trim adjustment holes have red LEDs on but I don't have a fault lights on. When I did install mach 3 it did install the printer driver. Is there a way to test the G540 by itself.
    Thanks for any help I can get
    Doug
    x2 Harbor Freight Mill with CNC Fusion Kit 2
    cncrouterparts 3-axis 23 nema Kit
    Geckodrive g540 version 4
    48 volt power supply
    Mach 3
    Dec 2013
    I can unplug the parallel and I don't get a red light fault. I only get a fault light when I push the emergency button. The motors have holding torque with the Parallel cable plugged or not. I was metering the printer cable and noticed a lot of the pins do not have connectivity.
    Apr 2004
    5741
    It sounds like you're using a parallel cable with some dead pins. These are made for applications that don't require full parallel port connectivity. But your mill does require that all the pins connect all the way through. Get another one which is like that, and your problem may be solved. Another thing to make sure of is that your computer BIOS is set to run the parallel (LPT) port in EPP mode.
    Andrew Werby
    www.computersculpture.com
    Dec 2013
    Yes it was the parallel cable I have motors spinning. I picked up a data transfer cable not a straight thru cable. Things are all good.
    Doug
  1. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  2. G540 and no movement on motors
    By alexdobert in forum Gecko Drives
    Last Post: 02-06-2013, 10:59 AM
  3. Mach3 Help with axis movement
    By CEStanley in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2012, 04:32 AM
  4. g540 X-axis problem - Holding torque but no movement
    By rlockwood in forum Gecko Drives
    Last Post: 09-04-2012, 05:00 AM
  5. Replies: 2
    Last Post: 08-21-2007, 12:21 AM
