586,494 active members*
1,615 visitors online*
Page 1 of 2 12
Results 1 to 20 of 37
    Jan 2006
    38
    DIY benchtop mill build
    Hello!
    Just wanted to share my build project It's my own design and will be mainly used to mill aluminum and MDF molds. More specs found on gallery comments. Feel free to ask if you have any questions
    Here's the link to my Picasa-gallery:
    https://picasaweb.google.com/1000918...3?noredirect=1
    Cheers,
    Mikko
    Feb 2006
    7063
    VERY nice! By far the best ground-up build I've seen here!
    Regards,
    Ray L.
    Your link is giving an internal server error.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jan 2006
    38
    Hmm, weird. Please try this one:
    Picasa Web Albums - Mikko Kuivamäki
    Choose CNC V3 folder to see pics
    I can see them now after I went to google first and logged in, works now, very nice!
    Hoss
    Jan 2013
    306
    Very nice build. Should perform well.
    Sent from my iPad using Tapatalk HD
    Feb 2006
    7063
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Works fine for me. Could be a temporary problem with your ISP...
    Like I said it worked fine once I logged in.
    Hoss
    Jan 2010
    151
    Hoss
    thanks for the tip hoss i was having the same problem. stellar work mikko, is that your vmc or one you borrowed the use of?
    Jan 2006
    38
    Quote Originally Posted by amyers View Post
    That vmc is used on nearby vocational school where the teacher and few students did frame machinings among their lessons
    Still someone having problems with that picasa link? I don't get it, the gallery should be public and visible for everybody without google login.
    Nov 2009
    4415
    Great work!
    May 2005
    3920
    Looking nice!
    The column is steel tubing but what is the base? It looks like the base is welded up out of solid bar stock.
    One other question why the bed mill design instead of a router type approach?
    Jan 2010
    151
    Looking nice!
    If you look at his album he's already built one of those.
    Dec 2009
    121
    Cool. Stands are so much more work than you first expect right? I love to see people doing analysis before they really get into the build. It's so useful to see how small changes can make sure a big difference in deflection or dampening. Keep up the good work. What do you think of the Leadshine servo-steppers so far? I'm incorporating them into a lathe but I haven't got anything wired yet. I'm curious to know how the perform.
    Jake
    Oct 2008
    1632
    Machine looks awesome! I only have one comment to make regarding the design and you may have already thought about it.
    Your Z Axis, is on linear rails, and the ball screw is direct driven. Is there enough weight there to free spin the motor and screw when there is no power applied?
    I initially had that issue with my machine after I first built it. When I powered the system off, the weight of the head would spin the ball screw and the head would come on down.
    Richard
    Nov 2012
    220
    Nice work! I like the solution you came up with for the base of the machine by using two pieces of box tubing welded to together--hadn't thought of that. I have started a scratch build design of my own and it looks very similar to what you have. Thanks for sharing!
    Jan 2006
    38
    Thanks for the replies!
    Jake
    I've done just initial tests without no load but so far they feels really good. Super smooth (and quiet) performance and lots of torque!
    I will put a 200N gas strut to lighten up the z-axis. I think the motor would have enough power to move it without counterweight but unpowered z-axis would come down.
    Jan 2006
    38
    Made first moves with X and Y axis :banana:
    I set rapids about to 7m/min. I also tested how fast this thing is and I got 20m/min speeds without losing any steps!
    CNC V3 XY test - YouTube
    1943
    Very nice. Quick too. One month from CAD to having the XY working. Impressive.
    Jan 2006
    38
    Actually it's taken now 11 months from CAD to this point.
Page 1 of 2 12
  1. Replies: 299
    Last Post: 10-16-2022, 01:54 PM
  2. 80/20 benchtop lathe build
    By LeeWay in forum Vertical Mill, Lathe Project Log
    Last Post: 06-15-2015, 01:35 AM
  3. Replies: 19
    Last Post: 12-06-2009, 08:23 PM
  4. Looking to build my own benchtop cnc!
    By rim basses in forum Benchtop Machines
    Last Post: 10-09-2009, 07:20 PM
  5. Not a Benchtop mill but Dang! You have to see this build.
    By praetor in forum Benchtop Machines
    Last Post: 05-19-2009, 10:58 AM
