586,089 active members*
3,958 visitors online*
Results 1 to 6 of 6
    Aug 2013
    11
    Table top/micro band saw?
    I would much rather have a full sized band saw but I simply don't have the room right now... Are there any good quality know brands that make table top band saws (hell, I don't even know if they exist but I figure I'd ask...)?
    Thanks.
    Aug 2013
    11
    Perhaps something like this would work, but I don't know what kind of quality I can expect from something like this.
    Portable Metal Cutting Band Saw, BS-127P | Baileigh Industrial
    Feb 2009
    2143
    I wanted a smaller bandsaw, but ended up getting a circular cold saw, and MAN am I glad I did. This thing EATS metal, I am so shocked at how well it performs. If you need to cut thick steel it might not be too good, but 1/4" steel and 6" extruded aluminum are no match for it.
    This is the one I got (and it states it will cut 2"x2" steel too...): Evolution Power Tools STEELSAW2 14-Inch Steel Cutting Chop Saw - Amazon.com
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    May 2005
    3920
    Way to little info. Vertical or horizontal? Cut off work or something more involved. The range of materials involved.
    If you are looking for something portable to do cutoff work seriously think about getting a portable bandsaw. You often see contractors using such. These saws can easily be put out of the way and when needed taken to the job site. Once you get past cutoff work usefulness declines significantly.
    Quote Originally Posted by Dye Guardian View Post
    Thanks.
    Aug 2013
    11
    Horizontal, only cut off. I think I am going to go the cheapest way for now which is simply a grinder with a zip wheel a belt sander to sand it flat/smooth... Then when I get the room I need I will get a full sized horizontal band saw. I should be able to get by for now.
    May 2005
    3920
    I have to admit to doing that myself for a long time, either a zip well or my Sawsall. I just got a small horizontal bandsaw last year, they are extremely handily once you have one. Need to cut some PVC for a plumbing job no problem. Electrical conduit No problem. Extrusions no problem. I even cut steel once and a while when the pressing projects are at bay and fun is set loose. ���� I have this dream of one day catching up with house remodeling and actually spending time in the shop for fun.
  1. Right Band Saw for the job.
    By Terry G in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2012, 07:14 PM
  2. Band Saw
    By kia94 in forum MetalWork Discussion
    Last Post: 06-13-2012, 08:59 PM
  3. 4 x 6 Band saw oil ???
    By twocik in forum MetalWork Discussion
    Last Post: 05-17-2008, 02:20 AM
  4. Micro Band Saw
    By tikka308 in forum Uncategorised MetalWorking Machines
    Last Post: 07-25-2007, 06:30 AM
