586,597 active members*
3,456 visitors online*
Results 1 to 15 of 15
    Mar 2006
    57
    Corian for a table?
    Has anyone here thought of using a piece of corian as a table for their router? I've been wondering what I should use for awhile now when I someone I know came across a good size piece that I could get for cheap. Also, how flat do you think corian is, and will it bow or dip in the middle? I plan on doing alot of engraving, and need to have the table as flat as possible. My table size is basically 36" X 36" and the corian is 1/2" thick. Waat do you guys think?
    Jason
    Aug 2004
    3215
    1/2" will bow on you unless you make a torsion style box from it or support it somehow with sq. tubing.
    Aug 2005
    276
    although it might not be FLAT and it might take some time, you can actually machine the top of the corian, this will ensure it will be square with you spindle head..
    you can even cut a sholder on the left and bottom of the Corian, this would create a step down and allow you to hold the sign square and the the same "0,0" point for each and every job...
    next option is to cut some slots in both x and y axis drill through to the under side, attach a few hoses and connect this all to a vacuume pump and as quick as a flash you have a level vacuume system that ensures your signs are aligned to zero,zero every time in a matter of seconds
    Just my 2cents worth
    Mar 2006
    57
    While we're on the subject, what does everyone here who has a decent size machine( table 36"x 36") use for a table? Been thinking about this for awhile now, and don't know what to use.
    Jason
    Aug 2005
    276
    here is the underside of mine - theory is sound but the excecuition, was poor (idea was to use C-section steal and place a thin compound to take up the uneven weld joints then lay extruded T-slot Aluminium on the table to hold down) as it was not done correctly ( Bought the machine from O/seas) this is what the T-slot Aluminium pieces look like from the top.
    Also you will see in the 2nd photo an idea of the cross section profile
    Aug 2004
    2849
    Well is you support everything on 4 legs....then you can use the legs to level your system.....and then the 'flatness' of the corian is well......
    Aug 2005
    276
    for leveling check out this thread
    http://www.cnczone.com/forums/showthread.php?t=19418
    to see how I did it have a look here
    http://www.cnczone.com/forums/showthread.php?t=14558
    Salty
    Feb 2009
    5
    Wink machine made of Corian
    Hello, I've made my table and aprons out of corian laminating 2 half inch peices glued using CA glue routed the edges top bottom to form a 1/4 lip in the middle of the peice to fit into slots in extruded aluminum 1x1 square
    Jul 2006
    1256
    Jason Corian is a very poor choice.It will sag if not fully supported.It is very fragile,similar to glass.Sheets come in 30"x10' If you and a buddy pick it up from the ends it will sag over a foot and snap.When used as a countertop it is glued down with blobs of silicone as a shock mount.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Feb 2009
    5
    Cool rebutle
    if you pick up any thing 30" wide and 10' long it will sag while other substrates may not break you would not leave it unsupported in a build corian is a fragile material but laminated to 1" thick gives great rigidity corion cuts like a dream mills great and in my opinion is better than wood
    Rebuttal #2
    I have to side with Larry here. While it may work in some applications, in general, it has more cons than pros for cnc machine use. In addition to being brittle, it also expands and contracts a lot with temperature changes. If not mounted to allow for this expansion and contraction, it can easily crack. And while it cuts and routes fairly easily, it's still more difficult to work with than wood. It's also expensive and can be hard to get.
    But if it works for you, use it.
    Larry, in the warehouse for our Corian distributor, I've seen them carry full sheets like you said. It bends more than a foot, but doen't break, unless you bounce it up or down.
    Jul 2006
    1256
    Jason I am a bit lost on the question.Is the corion the only base or table of the machine?I assume it is as you were worried of sag.If that is the case it is a very poor choice.I read the guys are using the corion on top of their aluinium T-tables.Fine,but an expensive spoil board.MDF is a better cheaper product which you would mill squaring up to the gantry when nessary
    Larry
    Feb 2009
    5
    back at ya
    Obviously you hav never worked with CORIAN my name is Chuck
    Jul 2006
    1256
    Chuck,I have worked with solid surfacing materials longer than I could imagine.As a table top material or counter top on a router it is very good to place your coffee cup.Our 5'x10' Thermwood router at work which cost $100grand plus $20 grand for the vacuum pump,plus $20grand in solidworks uses 2 sheets of MDF 3/4" thick as the table top.
    My .002 worth
    larry
    Feb 2009
    5
    here are pics of what iam doingClick image for larger version.
