586,075 active members*
4,125 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC 20 Encoder Fault Z Axis
Results 1 to 18 of 18
    Jan 2011
    15
    I keep getting an Encoder Fault and Servo Drive shutdown on my Z Axis when I try to calibrate and home my machine. Is there a way to test what is going on? If so how can I do this. I was thinking that the drive might be bad and I sent it in for repair. $1400 dollars later I still have the same problem. I checked my motor wires to ground and all seems fine. I don't know how to check the encoder. Any help would be very much appreciated.
    Nov 2006
    473
    Try slowing the speed down before you home it.
    Steve
    Jan 2011
    15
    How do I slow the speed down. This is a new to me machine. I did run the machine befor purchasing it and all was fine. The problem started when I got the machine in our shop. It has never worked here. Thanks for your reply.
    Nov 2006
    473
    I have a md3 with the ultimax 2 controller. I have a parameter screen where I can change the IPM. I also have a knob on the controller also.
    What controller do you have ?
    Jan 2011
    15
    It is a Ultimax 2. It has a pendant with it
    Nov 2006
    473
    When you turn it on, press the manual button, power button and then start button.
    Then press the input button, about half way down is the parameter button. Press that
    Then chance the second from the top. Start at half the value
    Jan 2011
    15
    Thanks, I will give that a try in the morning. Have you ever had this problem with your machine?
    Sent from my iPad using Tapatalk
    Jun 2013
    1041
    I have seen this message show up with a stuck limit/home switch on x. Check that the switch is not stuck.
    Ben
    Jan 2011
    15
    Thanks for the Reply. I will check that out also.
    ......... Steve
    Jun 2013
    1041
    Also its funny when you send somthing in for repair they charge you out the a$$ and it doesn't fix a thing. When this happens you just assume the charge was because they had to test it and they actually repaired nothing. Or maybe its for wear on there eyes for having looked at it to hard.
    Ben
    Jan 2011
    15
    Yes, that is what I have been thinking about all night. For that kind of money I did expect different results.
    ......... Steve
    Nov 2006
    473
    Can you post a picture of your pendant? I wish my Hurco had one.
    Steve
    Jan 2011
    15
    I will take a picture & post it tomorrow
    ...........ricochet
    Jan 2011
    15
    Hey Steve, I was wrong, my control is a Ultimate Max 3.
    I did slow the feed down. It was set at 400 ipm I set it to 100 ipm. I tried to calibrate the drive and it faulted again. I also checked the limit switches and the seen to be ok. Is there a hidden screen that I can go to see the limit switches to be sure they change state?
    I also put the machine in manual and was able to jog the X & Y axis. They work as expected. When I tried to jog the Z axis the drive a
    Faulted. The indicator on the drive shows a 1 and only the middle green led is on.
    .........Ricochet
    Jun 2008
    1104
    Your Servopack drive is faulty. Error 1 usually means a bad IGBT module. You could pull it apart and try replacing the module as a starting point.
    Jan 2011
    15
    What would cause the module to go out? I just got the drive back from repair and never worked. Where can I get a module? Thanks for the reply
    ...........ricochet
    Jun 2013
    1041
    Look it up on eBay. I've never heard of one but they have hundreds listed. Seem to be pretty cheap so maybe worth a try. Make sure you get the right one. What exactly happens when you try to home. Does it move at all or just fault right away?
    Ben
    Feb 2012
    67
    If it never worked in your facility, could it be a power issue?
    Tom
  1. Z Axis fault Error #16 Resolver Fault
    By centaur91 in forum Fadal
    Last Post: 10-06-2012, 05:01 AM
  2. X axis encoder fault/smoke
    By k4rd in forum HURCO
    Last Post: 10-02-2009, 12:15 AM
  3. Alarm 235 spindle Z fault, encoder belt?
    By slatern44 in forum Haas Mills
    Last Post: 08-17-2009, 07:54 PM
  4. Monarch Metalist 1A encoder fault
    By HMH in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2009, 07:54 PM
  5. Encoder at fault or not?
    By Adee in forum CNC Machine Related Electronics
    Last Post: 10-05-2007, 02:56 PM
