Rail cutting experience (inexperience?)...
Since I went from a 5X10 to a 5X5 table, I have to cut a couple of my linear rails from 3000mm to 1700mm. Originally, I had this brilliant idea of cutting the rail with a carbide end mill on my machine until I found out that the rail is harder than carbide and won't work. Okay, on to plan B - use a abrasive chop saw.
Went to my local rental place and rented an abrasive chop saw. When to HD and got a cutter. I wanted the thinnest cutter I can find but they only had a 1/8" cutter so I got that.
Got everything set up and started cutting. I've never used an abrasive chop saw before and certainly have never cut into hardened steel before, so I was very surprised at how much sparks were flying! Okay. Move the thing to a safer area where the sparks won't set anything on fire. Start cutting again. And again. And again. I knew that hardened steel is hard to cut that this was ridiculous. After 5 hours (yeah, 5 hours) of cutting, I had gone about 1/4" deep! This is not going to work!
Did a search on the net and found a video on YouTube of a guy cutting hardened steel using an angle grinder. The grinder went thru the hardened steel like butter! I didn't want to use an angle grinder to begin with as I know I will never be able to cut the rail straight. But at this point, I'll try anything.
Went to Northern Tool to pick up an angle grinder. Since I don't know a single thing about angle grinder, I got a sales person to help me. The guy was very nice and told me more than I would ever want to know about angle grinders and pointed me towards a Northern Tool brand called Klutch. I thought that it was a very strange name for a tool but the sales person convinced me that it was a very good tool for $60. The Milwaukee one that they had was about $100. Got home, opened the box and no handle! Since it was late at night, I had to wait till the next morning to go back to Northern Tool. I really wanted to finish cutting the rails!
The next morning, went back to Northern Tool to get a replacement. They didn't have any. The sales person took the handle off the display and gave that to me. Since I was anxious to get going, I took it and went home. Now put the cutter on the tool. What? I need a special wrench and I have no special wrench in the box either! Went back to Northern Tool and returned the thing. Told them that this is the first time I've bought a Klutch tool and will never buy another one again.
Went to HD to look for an angle grinder. They had Milwaukee, Makita, DeWalt and Ryobi. The Milwaukee was the most expensive one and the Ryobi was the cheapest. The Ryobi looked exactly the same as the Klutch that I just returned. But this one was for $40 and came with a case and different cutters. The HD associate said that the Ryobi was not as good as the Milwaukee, Makita or Dewalt but I like that I can put the handle on top instead of the side since I was cutting vertically. And you can rotate the switch too. Those features sold me on Ryobi. Anyway, I don't expect to be doing a lot of grinder and since it was the cheapest, I got the Ryobi.
Now for the real test - start cutting. The thing is going thru the rail like there's no tomorrow! Yay! Got thru the cutting in no time. As predicted the cut was not straight, but I'll take it.
