586,104 active members*
3,371 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How to add Leadshine alarm signal to e-stop chain?
    Jan 2006
    38
    Hello!
    I have Leadshine HBS86 hybrid servo drives and EdingCNC USB-CPU. Leadshine drives have a alarm output and I want to add this signal to my CPU's estop circuit. Could someone give advice how this should be done? I assume I cannot just put there outputs in series with estop button, I need somekind of relay circuit?
    I attached caption of Leadshine manual where is said how this alarm output works. Also attached caption how CPU's estop works.
    24221
    You may be able to add a relay or other sensor on the ALM+ and - open collector output, but it need s a bit more information as to the nature of the output?
    If you can add a small relay to these then a contact on the relay could be placed in series with the E-Stop circuit.
    Al.
    Albert E.
    Jun 2015
    9
    Re: How to add Leadshine alarm signal to e-stop chain?
    Adding to the same thread about HBS86 drivers alarm pin.
    HBS86 manual say that alm+ and alm- pins can sink or source 20mA at 24v, how much mA is it at 12v then? I am looking for a way to wire it in series with proximity switch, that runs on 12v 300mA, and then connect them both to ST-V2 (somehow sometimes found as mach3) breakout board limit/end switch pin.
    So, when stepper miss his step, driver go’s to error mode and then breakout board stops other axis movement.
  1. OMD 086 alarm DR signal Off when recivieing
    By meadowtech in forum Fanuc
    Last Post: 10-25-2013, 09:32 PM
  2. Leadshine MD882 Driver E-Stop
    By electrosteam in forum CNC Machine Related Electronics
    Last Post: 11-09-2010, 03:51 AM
  3. Using the Err/Res signal to e-stop Mach3?
    By fatal-exception in forum Gecko Drives
    Last Post: 08-05-2010, 10:29 PM
  4. dr signal off alarm
    By driftbuster50 in forum Daewoo/Doosan
    Last Post: 07-23-2010, 07:21 AM
  5. Replies: 2
    Last Post: 02-19-2010, 09:28 PM
