586,071 active members*
3,965 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Router for Hardwoods: Evaluation and Questions
Page 1 of 8 123
Results 1 to 20 of 145
    Aug 2013
    50
    Hello everyone,
    I am a furniture designer/maker who makes sculptural pieces of furniture out of solid wood. I have no experience with CNC, but I am sure that I will be able to incorporate one into my one-of-a-kind work flow. I am very excited about the whole process!
    I have been developing a design for a machine that synthesizes my needs with what I have learned from other posts. I know enough now to know that I know very little. Any comments or guidance would be greatly appreciated.
    The overview of the machine is: welded steel base, 8020 extrusion, plate aluminum cars, Hiwin linear rail, R&P, 4KW Chinese spindle with VFD and Nema 34 steppers…(all subject to your review). I am approaching the build in a few stages that will be spread out over the coming year.
    Clear space in my studio and evaluate size
    Weld the base
    x & y rails and cars
    z car
    steppers & spindle
    Electronics
    Learn how to use it!
    I am at the point where the various components are starting to work as a system in my CAD drawing. Thats the good part…the bad part is I am now seeing flaws in my plan and other areas of my inexperience are totally exposed! I have some specific questions in regard to sizing Hiwin blocks and in regard to setting up the Z axis. I will do my best to walk you through my design which will explain the thought behind some of my decisions. I am open to any and all suggestions that help me reach my goal of a capable CNC router for hardwoods. If the machine is rigid enough I could easily find some aluminum projects for the machine.
    Attachment 215994
    Base: The size of the base is the big issue for me. My studio is a fixed size with no hope of expansion. It would be ideal to have a machine that could accommodate sheet goods, but it is far from mandatory. In reality 30” of cutting width would be fabulous for my workflow. The long axis is more important to me and cutting 8 plus feet will be very useful. I mention the size because the design of the machine tries to maximize the cutting with of a narrow machine. I should point out that my machine will keep the top of the 80/20 rails below 34”. I realize that this is quite short short, but it affords me the freedom of allowing many of my other machines to pass material over the cnc.
    The base will be welded out of 14g steel with levelers. I can’t expect the base to be either flat or square enough for my taste. I plan on using the aluminum plates as a transition to the 80/20 so that I can either flatten or shim with the help of my 6’ Starrett straight edge and machinists level.
    Attachment 215968
    Spoil Board: I plan on having three layers of 3/4” material. The cut out in the front of the machine is for vertical work. I plan on hinging the plate so that it can angle to 45°. This will mimic some of the functionality of my multirouter but add CNC awesomeness! I should probably remove the bar in front of that part of the table but I am protecting my dream of supporting a full 4 x 8 sheet.
    Attachment 215972
    Attachment 215974
    Y-Axis:
    The rails will be made from 2040 series 10 80/20 extrusion attached from below and attached to the short sections of angle iron (to help reduce the tendency to rack). The Y cars are made of 3/4” aluminum with some of the vertical components made from 1/2”. I have designed the cars to allow for maximum movement in the x direction, a concession to the limited space in my shop. I have read enough about the Hiwin rails to know that I will be limited in terms of what legacy blocks I can actually find. I am curious if these blocks are adequate? LGW20HBZ1H blocks and rail. If I cant find them can I use the standard precision? What about the preload? For some reason I decided that Z1 appropriate?
    Attachment 215976
    Attachment 215978
    X-Axis
    3060 series 15 extrusion is at the core of the x axis. The same hiwin block and rail as the y axis are mounted on the top and bottom of the extrusion. Same questions about preload, precision and size?The spacing of the blocks also tries to maximize the reach of the router in the x direction.
    Attachment 215980
    Attachment 215982
    Z-Axis
    This is where my plan kind of unravels. All of my efforts to maximize the x axis movement crash up against the reality of clearing the spindle and my lack of experience. I have many questions: What is the relationship of the bottom of the spindle to the bottom of the Z plate? My design has the blocks permanently mounted and the stepper, ballscrew rails and plate moving. How high up should the spindle be able to go? I would like to get the bottom of the collet in line with the bottom of the x car. The answer to the first question effects how high I need to move the bottom hiwin block. If I try to achieve this I end up with the spindle hanging way below the bottom Hiwin block. Am I going for too much movement? Am I going about this in the wrong way? Perhaps I should explore pre-made Z options?
    Here are the images that illustrate some of my many Z axis questions:
    Attachment 215984
    If I line up the mounting holes on the spindle with the bottom of the z plate I will have to move the bottom hiwin block up much higher.
    Attachment 215986
    moving the blocks up will result in quite the overhang of the spindle. I have been looking at other machines and it seems that this sort of overhand is not unheard of.
    Attachment 215988
    Many thanks for having a look at my plan.
    Apr 2004
    5737
    [QUOTE=Sapele;1405722]\
    [The welded steel base won't be flat, but you knew that, right? To run those linear rails, though, they need to be mounted on something very flat, so you can either attach something flat to it or cast some epoxy to make a flat surface. Some people seem pleased with their Chinese spindles, fewer of them with the VFDs they come with. I'd suggest a Hitachi, but make sure it can make enough 3-phase power for the spindle from whatever power you're giving it. If you're feeding it single-phase current, it will need more going in than it will put out. The steppers will work, but wood wants to be cut fast, so don't rule out servos at this stage.]
    Weld the base
    z car
    steppers & spindle
    Electronics
    [I'd say put that last item at the top of your list. As you get into learning 3D CAD modeling, you'll get a better idea of what you want the machine to do. For instance, this machine is entirely dedicated to 3-axis carving at this point, but you might decide you need a 4th axis to do the designs you find yourself making. If so, thinking about that at the outset would be good. You might want to leave a space open to mount a 4th axis centered at table height, since that will double the diameter that can be accommodated under the spindle.]
    [Consider making it even shorter. If you run your gantry on raised "walls" (like the Mecmate design) it will be stiffer than if it's raised up on wobbly verticals. The walls can be as heavy as they want, since they aren't a moving part. There's no particular need for the router to be at table height, but you can put a table top over the walls (when it's not being used) if you need it to function as an outfeed table.]
    [You can always attach extensions to the table to support extra material. I like the idea of the cut-out for vertical work, but that will only work for short pieces (or very short pieces, if you take my suggestion above.)]
    Z-Axis
    [Your shortest tool still has to be the lowest point, or the Z-plate won't clear the material.]
    [That's pretty standard, although you can reverse that and have the blocks move while the rails and screw are stationary.]
    o How high up should the spindle be able to go? I would like to get the bottom of the collet in line with the bottom of the x car. The answer to the first question effects how high I need to move the bottom hiwin block. If I try to achieve this I end up with the spindle hanging way below the bottom Hiwin block. Am I going for too much movement? Am I going about this in the wrong way?
    [You just have to make sure that the collet is the lowest point, but can retreat so that it clears the work, or you're wasting headroom.]
    [I've used automation actuators for this; they've worked pretty well. If the spindle is heavy, you might find it drops when you turn off the power. A gas spring or two can help with that. Since you're making a rack & pinion design (at least in part), take a look at the kits offered by CNC Router Parts CNCRouterParts They've figured out a lot of the things you're still wondering about, or haven't got around to wondering about yet.]
    Andrew Werby
    www.computersculpture.com
    Aug 2013
    50
    thanks for the review awerby
    I dont want to neglect you point about learning to use the machine so I will address it first. You are absolutely correct in your suggestion- a normal person would start by learning how to use a machine and then go down the rabbit hole of making one. Unfortunately I know that I have to jump in in order to learn. This is far from ideal and I am sure that I will have regrets that will manifest in future revisions of the machine. The fourth axis is a good example of a feature that is not that relevant to my work, but I might want to implement at some point so I should keep the option open. Great point!
    Thanks for the suggestions of servos and the hitachi VFD. I am open to both and will do some further research.
    I see what you mean about the mechmate design. It does look quite robust. I am going to have to think about that design in terms of my needs. It would further reduce the limited vertical capability of the machine. I am looking forward to this ability so I might be stuck trying to make the wobbly parts as rigid as possible.
    I was working on a new version of the machine before your response. This represents a more robust version of what I had with the added benefit of being easier to epoxy level. I will dam up and bridge the two 4" tubes together so tha I can level the top. Then I will mount the 2040 extrusions with the hiwin rail.
    Attachment 216138
    Attachment 216140
    Attachment 216142
    Attachment 216144
    lastly a quick Hiwin question: I think I have seen some people use 4 of the AGH15SAZ1H for the Z axis. Are these adequate? I plan on using long block LGW20HBZ1H for the x and y. I am having trouble finding square block legacy hiwins with a Z1 preload so my options might be limited.
    thanks
    I don't like this, and don't think I've seen any machines with the steppers moving. Lifting the screw and stepper means you're moving a lot more mass, which means you'll need a lot more power to lift it rapidly. On a lot of home built machines, the Z axis is the limiting factor in the machine's performance.
    As far as Z travel goes. For me, I want to be able to reach the table with a 1" long tool, and if I have a 3" tool in the spindle, I want it to clear the bottom of the gantry when retracted.
    Yes, they should be more than adequate. However, careful Ebay watching can get you better quality pre-owned THK's for the same or less, if you're patient.
    Good luck. I have 8 LGW20's that I bought when the supply was very low, over a year ago. I still need to grab my 10' rails.
    Aug 2013
    50
    ger21 you have me wondering if the LGW20 are in stock or if they are just on the sellers website! Thanks for the confirmation that the AGH15SAZ1H would be adequate. I will continue the search. I have not been looking at the THK blocks so perhaps I will be able to find something since I have the time to search.
    I will re work the z axis with the blocks and rails flipped. I am curious to see which way results in better support for the spindle. I understand that there is more to the comparison when one takes into account the weight of the screw and stepper.
    thanks
    Apr 2009
    5516
    I normally don't see any big problems having the stepper on the carriage itself, provided it's sized right for the job. Usually the limiting factor with homemade machines is that finer pitch screws seem to be (I believe unnecessarily) used on the Z, along with wussing out on the power supply. The X and Y steppers move far more weight, and the stepper itself is pretty light in relation to the other componnents on the Z carriage.
    As to the bearing block arrangement on the Z, my belief is that if your overall Z travel is going to be small, say under 4", it would be best to mount the rails onto the Y saddle and the blocks on the carriage. If you need more Z travel, it would be best to mount the rails onto the carriage and have the bearing blocks fixed on the saddle. The latter would require more clearance below the gantry beam, but I believe it's a lot easier to beef up the gantry uprights than to add gussets and other supports to add to the weight of the carriage. There will always be a tradeoff, but one compromise is to mount your spindle on a plate with multiple index holes, and corresponding holes on the carriage plate. This way you can mount your spindle to suit the job at hand. I use a lot of stub endmills (<1/2" flute length) and my machine is set up where I can get the collet within 1/2" of the table. This is a more ridgid setup than having the collet 1" over the table and using a longer bit.
    Aug 2013
    50
    Awerby's point about the 4th axis encouraged me to think a bit more about the future use of the machine. The 4th axis is not that high on my list, but making a provision for it made the following clear to me. Having a section of the spoil board that can be removed to reveal a lower table would be very useful to me. This sunken pocket would be the place where I would mount the 4th axis. I will bolt the tube in light blue rather than welding it so that I can cut the spoil board out to reveal the pocket when it is needed.
    Attachment 216420
    Thanks to everyone for the information on the Z slide. I understand the following.
    If the blocks are mounted on the z carriage then the carriage plate must be beefed up to accommodate for the overhang. The overhang is needed because the bottom block can not extend below the lowest point of the yoke. The plus with this arrangement is that it is much easier to clear the bit over the bottom of the yoke. The downside is that the more Z travel then the greater the overhang which requires further stiffening.
    If the blocks are mounted on the yoke and the rails on the carriage then it becomes easier to reach the spoilboard but harder to clear the bottom of the yoke when the bit is raised all the way up. This situation forces the spindle to be placed on an adjustable mount and/or the y-beam and yoke to be raised. A bonus, as I see it, is that the overhang of the spindle is not fixed. The higher the spindle is raised the better it is supported (I am not sure this is actually true because it changes other forces?). When I think of the 1/2" bit scenario that louieatienza brought up isn't scenario 2 going to be better?
    Scenario 1- short bit with the work resting on the spoilboard
    Attachment 216422
    Scenario 2- short bit with the work supported on a fixture
    Attachment 216424
    I am in the process of thinking about me actual Z travel needs rather than my Z travel desire. The drawing below reflects me Z Desire
    I raised the y beam up almost 2 inches from where I had it and I
    Attachment 216426
    this view shows the spread of the THK bearings (HSR 20R) and the bearings height above the spoilboard.
    Attachment 216428
    I have no idea if I am being reasonable with my Z movement? Too much?
    The actual movement in this model would be 9" of travel from the spoilboard.
    Thanks and I hope everyone enjoys the last day of the year!
    I don't know why your mounting your bearings on the gantry like that. There's no reason to have that box surrounding the gantry beam. It actually causes a few issues.
    1) It's adding 1-1/2" to the bottom that you need to account for when calculating clearances.
    2) Having that box sliding from one end to the other makes it difficult to attach anything to the gantry. You typicallt want to use a cable chain, and with that design, you'll need a separate gantry beam or tray to support it
    It's much simpler to mount the rails to the front of the beam. That let's you drop the beam 1-1/2" and still have the same clearance, and reduces your travel requirements.
    As for your Z travel.
    What if you need to cut a sheet of plywood? In your scenario 2, you're not going to build a fixture to support large sheets or large parts.
    Also consider that realistically, you can't really cut much deeper than 3-4" with a 3 axis router. The reason is that once you reach your maximum tool length, you start running into clearance issues. You have to make sure the collet clears, and then the spindle body and carriage itself. I would guess that the max you'd be able to use would be in the 5-6" range, but it could be more in specific situations.
    Having more travel does allow you to make 3" cuts on 10" thick parts, though, if you have that need.
    But I would expect that 6-7" clear is more than enough for almost anything you'd be doing.
    Also consider that you can mount the spindle lower on the plate, and use some of the spindle length for your travel distance.
    On the machine that I'm building, I have the bearing blocks mounted to the spindle plate, and IO have just over 5" of clearance from the bottom of the gantry to the bottom of the collet. This gives me about 6" clearance with a 1" bit reaching the table. With 15" rails, I can left the collet about 4" above the gantry bottom.
    Here are some pics. http://www.cnczone.com/forums/cnc_wo...ml#post1155834
    Apr 2009
    5516
    The other thing is that you'll have this overhang regardless of Z position.
    I don't think that's an unreasonable amount of travel.
    For extrusions, look into Misumi GFS extrusions. Very heavy duty, and they can be purchased with wither short or wide faces milled flat.
    Aug 2013
    50
    great points. I had thought abut the e chain mounting issue and I thought it was an acceptable trade off for bringing the spindle 1 1/2" closer to the y beam. The way you suggest is much easier for sure. I will have to re draw it as you suggest and see how it all works together.
    the driving force of the larger Z travel has to do with my expectation of using fixtures under my 8/4 solid wood parts. I do cast a lot of concrete which could result in the need to carve out foam to make half of a casting form.
    Thanks for the link to your spindles. thats a nice setup! A great explanation of preload in the thread.
    louieatienza I forgot to mention that! I take that as the real advantage of placing the rails on the carriage.
    I am going to rework the whole system further exploring a number of different scenarios.
    Aug 2013
    50
    I just drew the z slide with the blocks mounted on the z carriage. The results surprised me. The spindle seems to be supported as well as the reverse system in most positions. Especially in the position that I plan on using it the most.
    shooting for the 9" of Z travel
    Attachment 216444
    all the way down
    Attachment 216446
    Overlaid with the previous system. The bright green blocks belong to the other arangement
    Attachment 216448
    If you all think that the overhang of the spindle in relation to the bearings is OK the blocks on the carriage seems to be an easier setup with the greatest usability (without re bolting the spindle)
    Apr 2009
    5516
    Quote Originally Posted by Sapele View Post
    Attachment 216444
    all the way down
    Attachment 216446
    Attachment 216448
    In the way you have it drawn, you have to have the Z trucks pretty close together to get the movement you want; i.e. you negate the advantage of the lower bridge by having the Z trucks close together like that. With the trucks fixed on the Y saddle, you could simply mount your spindle such that the collet is just slightly below the Z carriage plate. In short, with the moving truck design, regardless of how beefy you make the carriage assembly and Y saddle, the system will only be as ridgid as the spacing of the Z trucks dictate. You can gusset and plate the carriage all you want that will just add unnecessary weight. It is however obviously easier to build this way, and again if your Z is only moving 2-5 inches, the truck spacing in relation to the overall rail length would be greater.
    Aug 2013
    50
    Its been a long time since I took the easy way out of something! I now understand that my comparison did not reveal quite what I thought it had. I reworked the assembly as louieatienza suggested. I adjusted the position of the spindle collet in relation to the bottom of the z carriage, Moved the fixed blocks to the bottom of the Z yoke and increased their spacing a bit. Should I increase the spacing more?
    Attachment 216462
    Attachment 216464
    Jan 2008
    1529
    I've found it beneficial on my machine to have the spindle nose a fair bit below the bottom of the Z plate - this makes it easier to clear clamps etc (as you only have to worry about the small sized collet mutt and tool, not a wide plate)
    Apr 2004
    5737
    The second illustration above shows the problem with your idea of attaching all that hardware to the moving spindle. You've not only given it more weight to move, but you're dragging all that stuff down with the spindle, so that it's more likely to foul on any projecting parts of your work. If you leave all that attached to the Z-axis, and just attach the spindle to a plate with the blocks mounted to it, then just the spindle drops down, not the whole Z-axis assembly. So if you're carving a relief, like the Himalayas, for instance, the screw won't hang up on Mt. Everest while you're trying to carve the river valley below.
    Space the bearing blocks as widely as you can without compromising travel. And like someone else said, make a plate to mount your motor on that has a few different heights it can be fixed at, to accommodate longer tools or maximize rigidity with short ones.
    Andrew Werby
    Aug 2013
    50
    I do see the difference between the two systems:
    Attachment 216466
    Attachment 216468
    They both have major ramifications on the design of the other components. I plan on trying to refine both approaches as a part of my CNC's evolution. For a start I will have to space the blocks with greater care on the second example. I will consider giving myself the benefit of adjustability on both choices.
    Apr 2009
    5516
    Attachment 216466
    Attachment 216468
    Well let's consider the spindle fully down as the worst-case scenario. On the top configuration, there is more of a spread between bearing trucks. Also the rails themselves become part of the structure of the carriage. Note the lowest point the spindle is mounted to in both drawings. With the lower configuration, the relationship of the lower trucks to the collet (or workpiece for that matter) would always be in a worst-case scenario, regardless of spindle position. I would argue that this also increases the "lever" action against the gantry since the bearing blocks will be higher and farther from the center of the gantry beam.
    Again, if a majority of your cuts are as pictured in the second configuration, that might be fine, but then again if that was the case there would be absolutely no reason to have such a high Z clearance or travel.
    Bpth designs have merits and pitfalls, and there always will be tradeoffs between either designs. Just remember that just because a rail and block system has a max load rating, they still will deform under load (even preloaded rails) and there will always be a tradeoff between bearing truck spacing and ridgidity. Obviously the closer the bearing trucks, the more of a disadvantage they are mechanically.
    I also don't understand the fear many have about the weight of the carriage. The weight can be beneficial since there can be more resistance to vibration and deflection. Stepper motors are cheap enough that sizing up for the job won't break the bank. If you were making 1000 machines and were looking to save money MAYBE you'd consider a lighter and cheaper design.
    Aug 2013
    50
    I have been working on the Z with the fixed bearing trucks. I flipped the ball screw assembly around so that the screw, bearing blocks and stepper motor are now fixed. The rails and the ball nut are mounted to the Z carriage with the spindle. I dropped the spindles relationship to the Z carriage plate for more clearance as pippin88 suggested. The end result is just about 7" of travel from the bottom of a 2" cutter. I could reposition the spindle for further clearance via an adjustable mount.
    Attachment 216578
    Attachment 216592
    Happy New Year to all
    Jan 2013
    306
    That looks much better. Still not sure about wrapping the slide around the gantry. I think you would be better to leave it open as others have suggested.
    Steve
    Aug 2013
    50
    Thanks Steve.
    I like this configuration so I think it is time for me to consider the orientation of the X carriage trucks. I set them up this way so that the spindle would be a bit closer to the X beam. The bearings are also spaced a bit further apart than they would be if mounted to the front of the beam. Are these valid considerations? If not then moving the trucks to the front of the beam will allow the Y beam to get a bit lower and it will make mounting the E-chain easier.
Page 1 of 8 123
  1. Best sealing finish for hardwoods available in OZ
    By aarggh in forum WoodWorking Topics
    Last Post: 06-23-2013, 12:30 PM
  2. Surfacing hardwoods
    By eforer in forum Musical Instrument Design and Construction
    Last Post: 02-16-2012, 05:38 PM
  3. Rhino 3D evaluation & tutorial questions
    By dan j in forum Rhino 3D
    Last Post: 07-27-2011, 01:46 AM
  4. Cut hardwoods?
    By rbarr110 in forum Joes CNC Model 2006
    Last Post: 09-10-2009, 10:36 PM
  5. router feeds and speeds for hardwoods
    By belgrado in forum Musical Instrument Design and Construction
    Last Post: 12-12-2007, 04:19 PM
