I'm just getting started with a design for a router with a long skinny cutting surface (30"x96"). The bed is going to be a torsion box. I was wondering if it might be possible to drive the z axis with a single R&P mounted to the underside of the torsion box with the motor mounted on the gantry cross brace that goes under the bed. The rack would be centered under the bed.
Only going to cut wood or foam.
I'll try to get a quick drawing done here shortly. I'm just spitballing the idea right now.
Sent from my Transformer TF101 using Tapatalk
