586,075 active members*
3,749 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Why 80vdc max on drives?
    Aug 2004
    421
    I am looking at the possibility of retrofitting an anilam system to Mach. The system right now is 110vdc brushed servo, I think 10amps max. What is it that dictates the 80volt max? I guess it seems like an odd place to stop when 110 is easy to come by.
    If I were to use the G320, I would have to step the voltage down. Does anyone think performance would suffer?
    Joe
    If you try to make everything idiot proof, someone will just breed a better idiot!
    Apr 2004
    135
    The power MOSFET transistors used in the G320 are rated for 100 volts maximum.
    The G320 is rated at 80 volts in order to allow a little room to spare for safety.
    Using a lower voltage will result in the maximum speed of your servo motors
    dropping almost in direct proportion to the reduced voltage. The available
    torque is not significantly affected. For many applications the reduction in
    maximum speed is an acceptable compromise.
    Steve Stallings
    PMDX.COM - Products for CNC and motion control applications
    Aug 2004
    421
    This is a longshot, could there be an option to order with a higher rated transistor?
    I would rather spend more on the drive than add a transformer.
    24221
    Quote Originally Posted by jderou View Post
    Joe
    The usual design criteria to get optimum performance from the servo's, the power supply voltage should be designed for at least 10% above the motor rated voltage.
    And of course the drive have to be this capable.
    Al.
    Albert E.
    Aug 2004
    421
    Looks like I may be better off using the original drives and working on the interface between step-direction and analog.
    Joe
  1. How many watts can a G320 supply @ 80vdc / 20 amps
    By glengeniii in forum Gecko Drives
    Last Post: 01-11-2010, 05:24 AM
  2. Any use of old CD ROM drives?
    By transfrank in forum DIY CNC Router Table Machines
    Last Post: 12-29-2009, 12:13 AM
  3. The New Drives?
    By Adamj12b in forum Gecko Drives
    Last Post: 01-30-2009, 03:58 PM
  4. 12v drives
    By chester1957 in forum CNC Machine Related Electronics
    Last Post: 01-03-2008, 01:53 PM
  5. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
