Originally Posted by
jderou
I am looking at the possibility of retrofitting an anilam system to Mach. The system right now is 110vdc brushed servo, I think 10amps max. What is it that dictates the 80volt max?
Joe
The usual design criteria to get optimum performance from the servo's, the power supply voltage should be designed for at least 10% above the motor rated voltage.
And of course the drive have to be this capable.
Al.
Albert E.
