6 boxes with about a million parts arrived just before Christmas and have slowly been assembled into my custom 2448 machine. It is custom only in that the gantry Y is the short axis, not the X. I specified this for extra rigidity, but now that I have the machine assembled, I might have been OK with the standard PRO design which accommodates a much easier expansion to larger 48x?? formats.
The machine is assembled, cable chain installed and wiring routed to the end of the X axis tray. Proximity sensors are installed and I've just returned from setting up MACH3 and testing the sensors/tool setter. Apart from the pin setup not matching the instructions (Ahren said it might not) everything worked exactly to plan. Electronics consists of the Plug&Play Nema23 box, which I can tell you is first class in fit and finish.
What went wrong (and suggestions)
1. The Y axis rack was too short by a few inches. Ahren had shipped me a new rack immediately on receiving my email, but the old one will work for testing until it gets here. This is what can happen with custom machines I suppose.
2. I insisted on placing the electronics where the cables in the package didn't quite reach. The order was correctly configured for the normal placement and I could relocate the electronics, but I opted to order extension cables instead and stick with my plan.
A suggestion: The Plug&Play electronics package could either be auto ranging or switch selectable for 120/240V. Currently the changes need to be done when the unit is assembled for which ever power is appropriate. This would mean the fan would need to run on one of the power supply outputs rather than the input voltage.
and another: Accomodate a 5'th axis driver for those who want a 4'th axis on the machine. Ahren tells me he's already doing this - I was just too impatient to wait. The case for the current Nema23 package is not large enough to accommodate an extra driver and a new one is being sourced.
All in all I'm a happy camper and thank Ahren and everyone at CNCRouterparts for a great job.
Now if my Kress spindle and extension cables would get here............
