Hello,
Need some insight.
Setting up two sided machining for a part.
My issue is around the cutting depths. Part is centred in stock. Stock is square and square to table.
Cutting the "top" file is successful. When I flip the part and run the Gcode it cuts too deep and removes material it shouldn't.
My cutting depth is currently set to the middle of the part but on the "bottom" tool path the geometry is beyond the mid-point of the part.
When running this code it does not cut the geometry i need it to cut.
When I switch and set the cutting depth to the bottom of the stock and run the "bottom" code, an extra .125" of material is removed. Almost like the centre line of the geometry is overlapping somehow.
I've attached the files I think someone might need to help me out.
Sam
