586,103 active members*
3,651 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Facing won't seem to cut at right level
    Sep 2012
    62
    I have a stock piece with the top at Z zero. I have been trying to use Facing to cut it at 0.5mm below zero. I set the material top and material bottom at -.5. It just cut the surface at zero - despite the toolpath showing the cut at -.5 in Rhino. I also tried having "stock to leave" at -.5 but no difference. I tried material top at zero - no difference.
    Finally I just changed it to -.6 instead of -.5, and it's cut it properly.
    Is there something I'm doing wrong?
    Andrew
    Sep 2012
    62
    Problem solved ... I am so embarrassed - a very dumb mistake - it was a zeroing error - I was using the wrong thickness gauge to zero! Very sorry!
  1. G72 facing - oi TD
    By DC800 in forum Fanuc
    Last Post: 03-24-2012, 01:31 PM
  2. V22 Facing ?'s
    By bink in forum BobCad-Cam
    Last Post: 02-16-2009, 12:22 AM
  3. Facing operation
    By mikeh78 in forum BobCad-Cam
    Last Post: 07-14-2008, 11:08 PM
  4. Facing around a boss
    By macona in forum Mastercam
    Last Post: 06-07-2008, 08:40 AM
  5. Facing
    By impact in forum MetalWork Discussion
    Last Post: 02-23-2006, 03:24 AM
