587,028 active members*
3,153 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > emco 345 1019 low pressure lubrication alarm
    Sep 2013
    7
    i have an emco turn 345 with a fanuc 21 t controller after every cycle it throws up an alarm 1019 low pressure central lubrication alarm.
    i have replaced the sensor , the pump, replaced all the lines no leaks but still get the alarm. is there a way to bypass this to keep running some one please help
    Aug 2007
    793
    you may make a link (or inside out remove "link" by disconnecting wire from screw terminal or unplugging the connector)
    if it doesn't help, the problem probably lays inside I/O circuit
    then you have to look into ladder to find out how to bypass the input
    Sep 2013
    7
    thanks
    Sep 2013
    7
    ok i un hooked the wire didnt change does any one know how to bypass the input thru the ladder
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Alarm 256 Head Lubrication Alarm
    By jb2560 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2012, 03:53 PM
  3. alarm 1019, 1041, 1042
    By tushar26d in forum Fanuc
    Last Post: 09-02-2011, 08:14 AM
  4. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
  5. alarm code 1024,1019
    By bob1427 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-13-2009, 12:36 PM
