586,455 active members*
3,589 visitors online*
    Jan 2014
    Simulation error
    Hello everyone!
    I have a problem with Solid Verify simulation within SolidCAM2011 that I'm trying to solve for a long time, hopefuly an experienced programmer will help me out.
    The thing is, when I start a simulation on a single operation, the previous ones are not showed, so it behaves like there is no prior operation. Then it usually crashes. When all operations are simulated at the same time, it works correctly.
    Do you have any idea what may be wrong?
    Thank you.
    Feb 2013
    49
    i depends on what operation you are trying to verify. i think for 2D machining operations (pocketing, etc) it does not require an updated stock to run simulation. for operations like imachining or hsm, it will require updated stock for verification. will check later if there is a setting to force all to require updated stock for verification.
  1. V25 Simulation Error
    By gerinipus in forum BobCad-Cam
    Last Post: 08-22-2013, 10:51 PM
  2. Simulation Error
    By seal1966 in forum BobCad-Cam
    Last Post: 08-15-2013, 07:25 PM
  3. simulation error- happens often but not always
    By hatchmar in forum BobCad-Cam
    Last Post: 07-11-2013, 09:21 PM
  4. error during simulation
    By danny_wine in forum UG NX
    Last Post: 07-03-2013, 09:25 PM
  5. V25 error on mill simulation
    By Higgs in forum BobCad-Cam
    Last Post: 05-07-2013, 06:23 AM
