586,052 active members*
4,294 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > vibration problems vm24
    May 2006
    196
    in two different quadrants, no matter how small the cut length of the tool anything, i cant get rid of the chatter. its two opposite corners, and aside from checking the ballscrew and bearings for slop i dont know what else to do .
    Mar 2006
    370
    Did it just start this problem? I assume you refer to two opposite quadrants in the X-Y plane.
    Have you checked the level? Could the machine have moved or the concrete have settled? I am not sure how this could cause the problem you have. . .just throwing out ideas.
    Dave
    Jan 2004
    3154
    Check that the mounts are secure on the linear rails and on the bearing blocks.
    www.integratedmechanical.ca
