586,094 active members*
3,872 visitors online*
IndustryArena Forum > CAD Software > ViaCad / Shark > My 1st Real Parts (draft)
    Jan 2006
    93
    so, as a newbie, i need CAD to make parts like this. these are not 100% to correct size, but the scale is about right. in general, the outside dia is 1".
    i am getting more familar w/ the tools as i muck around, etc. to be honest, the Camera tool (pic-to-file using ray trace w/ anti aliasing) is cool, i like this item, not sure if its the non-Pro version, forgot to check before i uninstalled 2d/3d trial and installed Pro.
    your comments welcomed.
    also, i need some help creating threads on round/tubular/solid parts, eg; the turbine looking thing needs 40tpi on it. i saw some older posts on other forums about creating a helix and then using that to cut the threads, but i need help with this.
ID:	217652Click image for larger version.
ID:	217654Click image for larger version.
    Sep 2012
    1195
    Good work, looks like you are figuring it out. Is that a flywheel of some sort?
    Jan 2006
    93
    no, its used as a baffle. in essence, a fancy exhaust system. that spiral section gets covered w/ a flat disc, etc.
  1. looking for a draft horse or team of draft horses
    By glaciallakesmfg in forum MetalWork Discussion
    Last Post: 06-07-2013, 04:45 AM
  2. First "real parts" made on the Torus Pro
    By AUSTINMACHINING in forum Novakon
    Last Post: 05-30-2013, 04:06 AM
  3. draft
    By dustinwassner in forum Moldmaking
    Last Post: 06-27-2010, 03:36 AM
  4. Real, real newbie!!!
    By aggie_67 in forum Uncategorised CAM Discussion
    Last Post: 02-04-2006, 07:10 AM
  5. First 'REAL' parts = PICS
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 11-16-2003, 06:15 PM
