waterjet, water jet, waterjet cleaning machine, Bitong Technologes is the leader of waterjet machinesBTECH CNC waterjet cutter combined with CNC plasma cutter
Plasma cutting is low cost of equipment, fast cutting speed, and low running cost.
With CNC height control, cutting edge is smooth, and size is accurate.
Suitable to cut most of conductive materials.
CNC controlled for complicated 2D shape cutting.
High cutting power selection of 100Amp, 200Amp, 400Amp.
High speed cutting, cost effective.
Accurate and smooth edge.
Low comsumable and maintenance cost.
Combined waterjet cutting and plasma cutting, sharing the same CNC controller and cutting table.
Based on waterjet cutting machine, plasma cutting is added to it..
Advantage of versatile cutting with waterjet and fast metal cutting with plasma.
Use waterjet to cut thick metal or non-metal, and plasma to cut thin metal fast
Learn one set of software and CNC controller.
Material on the same cutting table, save time for loading/unloading.
Less machine to maintain.
Occupies less floor space.
