586,061 active members*
4,358 visitors online*
Page 6 of 6 456
Results 101 to 107 of 107
  1. #101
    Feb 2005
    829
    Re: Starting New CRP4848 build
    Baltic birch will be void free, and very expensive. Also anything sold as marine grade will be void free also, and more expensive.
  2. #102
    My preference for sealing MDF is epoxy. Do a slightly oversize finish cut, say .01 oversize, then brush on a coat of epoxy. Let cure, and redo the finish cut to the actual size. You'll get a glass smooth finish that requires no sanding or sealing.
    The downside, is that it's time consuming.
    Here's an MDF textured panel I did this way, and painted right off the machine.
    http://www.cnczone.com/forums/cnc-wo...ml#post1081719
  3. #103
    Feb 2005
    829
    Can I ask what paint you used to paint the unused portion of the steel railes? I want to do this on my machine to have less area to worry about rusting.
  4. #104
    Oct 2008
    1632
    I used Rustoleum Safety Red in the spray can.
  5. #105
    Jun 2013
    88
    Hi Guys,
    We use Cardinal RD02 powdercoat on our components.
    Cory
    CNCRouterParts
  6. #106
    Feb 2005
    829
    rwskinner, thanks. Was it a close match to the powdercoat? From the pictures it looks pretty close.
  7. #107
    Sep 2012
    228
    Hello rwskinner,
    I just found your posts.... I love what you did and thank you for the photos and details... they help us work on our projects...
    I am curious about your electronic enclosures...
    They seem to be plastic... do you recall where you got them and about how much they cost....
    The metal NEMA type enclosures seem nice but they are like $200 which seems like a lot for just a box....
    I don't know if the metal has some special advantages like cutting down on EMI but I think plastic would be easier to cut and drill to add buttons and switches.
    Would you be able to tell me more about your boxes and any other thoughts you would like to share? Thank you Very Much.
Page 6 of 6 456
  1. CRP4848 Nema 34 Build
    By nlancaster in forum Avid CNC
    Last Post: 12-03-2016, 02:06 AM
  2. Build Planning CRP4848
    Last Post: 04-01-2014, 12:56 AM
  3. CRP4848 build log - Coeur d'Alene, Idaho
    By cncrr in forum Avid CNC
    Last Post: 03-02-2014, 01:54 AM
  4. New CRP4848 Build from Central Texas
    By TurnTex in forum Avid CNC
    Last Post: 10-01-2013, 10:40 PM
  5. CRP4848 Build has begun
    By Silver-Fox in forum Open Source CNC Machine Designs
    Last Post: 12-27-2012, 03:18 PM
