586,058 active members*
3,366 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Gantry - (2) 2 1/2" vs 7" cold rolled steel
Results 1 to 8 of 8
    There is an obviously a slight difference in weight, but are there any advantages/disadvantages to using 2 pieces of 2 1/2" CRS vs. a single 7" piece?
    Mar 2011
    584
    I'd say $ being the biggest factor. The good thing aobut the smaller pieces over the 7" one is you can adjust the edges so they are parellel to each other. good thing about the 7" is you don't need the clamps.
    Surprisingly, there is only about a $20 difference, 7" being more expensive. That difference is negated by the cost of the number of clamps I'd need over the 84" length.
    Feb 2004
    1086
    Bob,
    If you can get actual 7" cold formed, that's a good way to go. It can sometimes be dicey to get this material, as it is sometimes sheared from sheet rather than cold extruded like the 2.5" stock, which means the edges and dimensions are not nice and square, so make sure to check on that.
    For us, shipping and stocking are easier if all of our material is 2.5", so this is more cost effective in the end for our kits. If you are making your own rails, and can get nice 7" material, I'd go for it! This should be somewhat stiffer as well.
    Best regards,
    Ahren
    CNCRouterParts
    Re: Gantry - (2) 2 1/2" vs 7" cold rolled steel
    I'm resurrecting this old thread... Is there an optimal number of bolts or bolt spacing for attaching the 7" plate to 8020 extrusion? Such a thing as too many bolts?
    Feb 2004
    1086
    Hi Bob,
    You can never have too many bolts In general, we bolt our steel down every 6", and 3" from each end and this has worked well. If you want to go closer pitch than this you are welcome to.
    Best regards,
    Ahren
    CNCRouterParts
    Thank Ahren. I think 40 bolts should be enough... Click image for larger version.
    Feb 2005
    829
    That looks like a perfect match on the paint there bob. Great looking machine.
  1. First build "Steel Gantry moving table"
    By charlieslasher in forum DIY CNC Router Table Machines
    Last Post: 04-11-2017, 03:50 PM
  2. Boring a 1-3/8" hole on a 5/8" thick 3"x3" cold rolled steel bar
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 02:49 AM
  3. building linear rails with 1" cold rolled round stock
    By Hackberry jake in forum DIY CNC Router Table Machines
    Last Post: 05-03-2013, 05:42 PM
  4. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  5. cutting oil for 1/4" cold rolled steel?
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 03-19-2009, 05:50 AM
