good day to all,
I'm also in the process of building my first cnc router.
I do however have a question regarding gear reduction on the stepper motors. The norm seems to be a small gear/pulley on the motor and a larger gear/pulley on the lead screw. This arrangement provides a certain speed : torque ratio, since most of the lead screws are acme, multi-start threads.
Now, my lead screws will be metric, M12 * 1.75mm. In order to keep the motor speed within the max torque limits, I was wondering what the effect would be if I reverse the normal arrangement, i.e small gear on the lead screw and the large gear on the motor. This will produce more speed at lower motor rpm's, but ..........?
Could this arrangement work, or would I damage my motors/controller or something else?
Any help will be appreciated.
Greetings from Dark Africa.
