586,082 active members*
3,918 visitors online*
Results 1 to 6 of 6
    Jan 2011
    metric to inch
    Hi
    how to change machine type default metric to inch in macam5
    the settings won't do it
    it appears to be permanent
    hope you can help
    much appreciated
    don
    Oct 2008
    2100
    Sorry, not a mastercam user although in other software stuff like that is in prefferences. If all else fails remember 25.4, and keep a calculator open.
    Bob La Londe
    http://www.YumaBassMan.com
    May 2012
    180
    Change your config file. And for it to be default needs to be the startup file.
    Sent from my HTC One using Tapatalk
    Dec 2019
    You must contact the person who provided the camera services locally he can batter understand your problem and fix it easily. Most of the time there is the error with zipjobs setting and you need to fix wisely.
    Dec 2019
    6
    hi
      if you machine� �is inch,you can � ��lt+f8 in master  cam  to change i� �ch mode.
    Dec 2019
    6
    hi
  1. inch to metric Osp700 L
    By Berzunza in forum Okuma
    Last Post: 05-15-2013, 12:45 AM
  2. Metric to Inch
    By Noquarter in forum Education - Teachers and Students Hangout
    Last Post: 10-17-2012, 05:37 PM
  3. Should I design in Metric or Inch?
    By jupdyke in forum Mechanical Calculations/Engineering Design
    Last Post: 08-18-2011, 05:48 PM
  4. 21-T, 18-t inch metric conversion
    By mike9696 in forum Fanuc
    Last Post: 07-25-2008, 05:48 AM
  5. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
